Results 1 to 10 of 10
    Junior Member Two Rings
    Jan 07 2021
    Florida USA
    right/ left rear indicator lights (sides) Error - 2018 Audi S7
    A few days ago, I started getting an error code on the dash regarding my right rear light. Upon inspection, the light was working, but I went ahead and ordered LED replacement bulbs even though these were not LED's to begin with. I replaced both sides, turned on the car and the lights work just fine, however the dash throws an error on both sides now, which is annoying. Is there anyway to correct this through VCDS? Or do I need to order the OEM non-LED version as the only way to correct this?
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Garyn06 View Post
    This might depend on the brand of replacement LED. Other AZ threads imply that if the replacement LED is not properly engineered, an error will occur.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Many have gone into VCDS and coded the marker lights off and no longer worry about them. I have seen shops online that you can get body colored inserts to eliminate the marker completely once coded off.
    Or get original style bulbs and change them out. Not really sure you are saving much of any power with LEDs in those locations and I am not really sure it would be brighter or dimmer than normal stock type bulb.
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Valpo A7 View Post
    Probably depends on several factors. I replaced my back up and fog bulbs with LEDs from an AZ sponsor and they are somewhat brighter than OEM.
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    I do know that LED's use substantially less power, so maybe your car is seeing that theres less power than usual and assuming a light is out?
    Daily -2015 Audi A7 Prestige| 20% rear & 35% front 3M Ceramic IR tints|Custom Alcantara Starlight Headliner|
    Music, Real Estate, and Audi
    Jan 07 2021
    Florida USA
    I believe some of you were correct in that the LED gives uses less power, so the draw wasn’t there. I went ahead and ordered OEM replacements and swapped them out, which has since cleared this error and it hasn’t represented itself since.
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    I have aftermarket LEDs purchased from AZ sponsor deAutoLED with no error codes.
    Veteran Member Four Rings quattroism25's Avatar
    Jun 04 2007
    Exiled in Utah
    I didn't know you could code out the side markers in VCDS. Do you have instructions?
    Daytona Grey S7
    MORO BLUE JHM modded V8 Sold
    Nov 27 2018
    Valparaiso, IN
    Quote Originally Posted by quattroism25 View Post
    Never done it as they don't bother me but the VDCS cheat thread covers it.
    https://www.audizine.com/forum/showt...-list-and-help
    DISABLE AMBER CORNER LIGHTS.
    OBD11
    https://www.youtube.com/watch?v=fRJ6TSy733o
    Jun 04 2007
    Exiled in Utah
    thanks
    Daytona Grey S7
