Results 1 to 3 of 3
    Feb 12 2004
    '01 RS4(B5)2.7T, '07 A3 2.0TDi, '12 Q5 2.0T, '13 Mk6 GTI
    Q.C., Philippines
    q5 b8 springs on q5 b9
    Hi is it possible to use my old q5 b8 (2.0T) springs on my q5 b9 (2.0T)? TIA
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    I don’t think they cross, check OEM P/N’s of booth to see if they are the same
    Jul 16 2018
    Atlanta
    https://www.audizine.com/forum/showt...-compatibility
    Should give you a good sense that the springs are not interchangeable. Which was the basis of the problem in that thread (coilovers for B8 do not fit the B9, at least in the rear).
    Can already tell you the part numbers are not going to cross. B8 Q5 springs are 8R0.... B9 Q5 springs are 80A....
