Results 1 to 3 of 3
    Veteran Member Three Rings shreddykrueger's Avatar
    Feb 14 2016
    S4 Avant
    Macan/S4 Brake Kit
    Selling as a complete set:
    Porsche Macan 4 piston front brake calipers
    ECS drilled/slotted 345mm brake rotors
    Audi s4 rear brake calipers
    ECS drilled/slotted 330mm brake rotors
    EBC red stuff brake pads (front/rear)
    Stoptech ss braided brake lines
    Was running on my s4 avant but just upgraded to a BBK.
    Calipers are Powdercoated Tiffany Blue (prismatic RAL 6027). Macan calipers we’re installed Jan 26, 2023). Current decals were clear coated in but not high temp as advertised and turned a pale orange color. Can easily lay new decals over to cover up if you do not like, or just Powdercoat an entirely different color :)
    Pads/rotors have roughly 20k miles on them. One of the fronts has an intermittent squeak and could probably just use a little squeal. These are bolt on and ready to install.
    Will work on a variety of platforms, do your research. I was running on 2011 s4 avant
    $1200 located in Denver
    S4 Avant (6MT)
    RCP dual pulley | AWE touring | JHM catted/baffled DP's | AEM water/meth | Ringer Stage III | RSNAV | Vogtland Coilovers | many other tings
    Mar 31 2008
    eS-4
    CAL*SO
    any lips on rotors?
    Feb 14 2016
    S4 Avant
    SOLD
    S4 Avant (6MT)
