Hi all,
Over the past week while driving on the highway my car has displayed the EPC error code and the check engine light flashed. The first time I made it back home, turned off the car and everything cleared. 5 days later it happened again on the highway and now the check engine light is constant on the dash.
Here are the Vagcomm codes:
5 Faults Found:
17875 - Exhaust Pressure Control Valve
P0475 00 [040] - Electrical Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 93
Mileage: 170086 km
Date: 2023.04.24
Time: 18:40:47
Engine RPM: 1956.50 /min
Normed load value: 32.5 %
Vehicle speed: 114 km/h
Coolant temperature: 96 °C
Intake air temperature: 28 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.088 V
Unlearning counter according OBD: 17
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [172] - -
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 174531 km
Date: 2023.06.13
Time: 22:35:05
Engine RPM: 1917.50 /min
Normed load value: 20.8 %
Vehicle speed: 111 km/h
Intake air temperature: 38 °C
Voltage terminal 30: 13.923 V
Unlearning counter according OBD: 40
10598 - Cylinder 8
P0308 00 [172] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 174531 km
Date: 2023.06.13
Time: 22:35:05
10596 - Cylinder 6
P0306 00 [032] - Misfire Detected
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 174532 km
Date: 2023.06.13
Time: 22:35:18
Engine RPM: 1904.00 /min
Normed load value: 23.1 %
Vehicle speed: 110 km/h
Coolant temperature: 97 °C
Intake air temperature: 33 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.900 V
Unlearning counter according OBD: 25
10205 - Cylinder Disabling
P130A 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 174532 km
Date: 2023.06.13
Time: 22:35:19
Engine RPM: 2064.50 /min
Normed load value: 21.2 %
Vehicle speed: 16 km/h
Coolant temperature: 100 °C
Intake air temperature: 37 °C
Voltage terminal 30: 13.711 V
Any thoughts or suggestions would be welcome. My local indie shop wants to replace the coils on cylinders 6 and 8 given the errors.
Should I think about going into Vagcomm and deactivating the engine from going into 4 cylinder mode while cruising as I do see a big puff of smoke out of the exhaust when that cycle ends and all cylinders are activated.
Any feedback would be greatly appreciated!
