Hello guys, so I have a 2010 Q5. A few months ago my radio unit died (I believe my MMI was not turning on). I read about the bypass and did light research and for most, it was the radio unit. Since this was easier to get to, I tested it out first and MMI turned on once I bypassed it. I went to the recycle yard and picked up another radio unit with part number 4F0035082A. The guy on Youtube plugged his in and it worked...he never mentioned anything about CP or going to the dealer. I plug mine in and everything works; only I get that enjoyable CP cutoff like a CD scratching. I initially went to the dealer to get CP removed. The service manager knew exactly what I needed and quoted me $90 which I was already expecting $100 to $150. I agreed to have them work on it. The car went to the back and the tech advised the service guy that it will cost $300 because it takes an hour and 30 minutes to do. I tell them I will take the car back and left.
So after doing more light research there were a couple of options that came up. Pulling the EEPROM from the PCB and reading my original CP info, then writing it onto the new one which also requires pulling it off the PCB. Another option I saw come up was just straight swapping the EEPROM from one unit to the other. I opted for just swapping the EEPROM. So I swapped EEPROM from my old unit to my new unit. Plugged it in and cleared the codes with VCDS. Only problem I saw was that the module identifies as some alien language. Normally you would see the part number. On this swapped unit it doesn't (examples below). Good thing is that it removed half of CP though. So I run the RSNAV and when listening to music through "External" source sound works fine. When trying to listen to the radio, I get the CP remix.
Seeing the readings of the differences in part numbers below (bold and underlined), did I fry my old EEPROM or something? Is there a step when swapping EEPROMs that I do not know about? Also looking at the logs when the unit is working, the speakers show something is wrong. Not sure how to fix this since I never touched the speakers and there were no faults prior to me swapping modules. Is straight swapping EEPROMs a myth? I can see the need to read CP from the old EEPROM and just rewriting the CP on the new EEPROM, keeps everything else in tact. So the straight swap EEPROM is not an actual working way?
Sorry if this is not the correct section to put it in and sorry for the novel.
Saturday,17,June,2023,22:06:18:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335J.097532186
Coding: 020000020100000000
Shop #: WSC 02391 823 56573
VCID: 1D67D969ADB2303358D-8048
7 Faults Found
00419 - Left Front DSP Midrange Speaker (R103)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 146
Mileage: 292540 km
Time Indication: 0
Date: 2023.06.17
Time: 21:59:04
Freeze Frame:
Voltage: 12.00 V
00420 - Front Right DSP Midrange Speaker (R104)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 146
Mileage: 292540 km
Time Indication: 0
Date: 2023.06.17
Time: 21:59:04
Freeze Frame:
Voltage: 12.00 V
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 146
Mileage: 292540 km
Time Indication: 0
Date: 2023.06.17
Time: 21:59:04
Freeze Frame:
Voltage: 12.00 V
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 146
Mileage: 292540 km
Time Indication: 0
Date: 2023.06.17
Time: 21:59:04
Freeze Frame:
Voltage: 12.00 V
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 146
Mileage: 292540 km
Time Indication: 0
Date: 2023.06.17
Time: 21:59:04
Freeze Frame:
Voltage: 12.00 V
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 146
Mileage: 292540 km
Time Indication: 0
Date: 2023.06.17
Time: 21:59:04
Freeze Frame:
Voltage: 12.10 V
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 146
Mileage: 292540 km
Time Indication: 0
Date: 2023.06.17
Time: 21:59:03
End----(Elapsed Time: 02:42, VBatt start/end: 11.4V/11.3V. VIgn 11.4V)-----
Monday,19,June,2023,16:29:10:16365
Address 56: Radio (R) Labels: None
Part No: ,§€ˆÓ€¸C¬
Component: Radio U SIRIU 0021
Shop #: WSC 00000 000 00000
VCID: 75B7E1C975C2C87370D-8020
9 Faults Found
03175 - Invalid Data Set
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Voltage: 11.30 V
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Voltage: 11.30 V
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Voltage: 11.30 V
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Voltage: 11.30 V
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Voltage: 11.30 V
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Voltage: 11.30 V
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
03454 - Functional Restriction due to Implausible Signal
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 292540 km
Time Indication: 0
Date: 2023.06.19
Time: 16:28:28
Freeze Frame:
Bin. Bits: 00000000 00001000
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 255
Time Indication: 0
Freeze Frame:
Voltage: 11.30 V
Bin. Bits: 00000000 00001111
