Results 1 to 1 of 1
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    JHM Power Connect Cable $120 - SOLD
    JHM (POWER CONNECT) ECU-TCU Flashing Cable for all B7 TCUs ONLY and all B7 A4-RS4, B8, C7, D4, C6-A6 3.0t, 4L Q7 3.0t, C6-S6 V10, D3-S8 V10 and newer ECUs and TCUs. Sold the car and no longer have any use for it. $120 + shipping and it's yours.
    Per JHM Website:
    *NOTE: THIS IS THE POWER CONNECT CABLE ONLY for all B7 TCUs ONLY all B8, C7, D4, C6-A6 3.0t, 4L Q7 3.0t, C6-S6 V10, D3-S8 V10 and newer ECUs and TCUs!!! For all B7, B6, B5 and C5 ECUs you must also purchase our (OLDER TUNING) cable for flashing which is different from this cable**
    UPDATE 4-1-21: All C6 S6 V10s and D3 S8 V10s use ONLY the one POWER CONNECT cable to flash BOTH ECU and TCU. So if you have one of these cars do NOT buy the OLDER TUNING flash cable. This is the ONE and ONLY cable you ned to do BOTH ECU and TCU.
    UPDATE AS OF 1/23 B7 A4/RS4 TUNING HAS MOVED TO OUR POWER-CONNECT FLASHING SERVER
    SOLD
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
