Got another A4 b6 and noticed the brake light was on. Checked the sensors and saw the front one was unclipped and ripped out of the pad. The guy who sold it said it has all new brakes. Naturally wanting to see how bad I am at buying stuff I decided to check everything and realized every pad was a different brand along with the calipers. The rear were non existent and was halfway through the metal, front were just done and sensors ripped because they were never plugged in. Removing the pads I realized the one front and one rear caliper had bad pistons so in the end because parts are cheap here for some reason I did brembo pads and new Audi original calipers all around. Fast forward a few hours in my apartment parking lot and Im now bleeding the brakes. Now not being familiar german cars I did the wrong seqience and started at the rear. I know the sequence now. My concern is I have read I need to have the engine running? Im not using a pressure bleeder but the 2 person pump pump hold method. When I originally bled the brakes in the wrong sequence i had no air and solid fluid and got a good stiff pedal. But when i started the car to go for a test drive the pedal dropped bad and wouldnt pump hard but would still pump. I could stop if I wanted to but it is definitely not a good pedal feel or safe for main roads. I also read something about using vcds to reset the ABS? I think I have vcds but havent used it yet and am not familiar with it at all. Also read something about needing to bleed the clutch now too? When I went for the test drive clutch was fine and pedal was good.
I know this stuff has been posted before but they are old threads and stuff changes, just trying to get a clear definitive answers.
Sent from my SM-N975F using Audizine Forum mobile app
