Results 1 to 3 of 3
    Junior Member One Ring
    Feb 13 2013
    poconos
    Water pump housing
    Does anyone have a link to replacing the housing ? The dealer won’t replace the water pump even tho it’s a known issue . They are saying the housing is bad causing the temp to rise .
    I’m going to replace the housing first and take it back for the pump if it doesn’t fix the issue
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    check pm
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jul 16 2018
    Atlanta
    You have to be careful with the word selection. For B9 2.0T, there's now the "water pump", which has leaking issues. This is just the belt driven impeller and the end plate it's mounted into. And then there's the thermostat housing, which has electrical failure issues.
    https://www.ilcats.ru/audi/?function...25&language=en
