Results 1 to 3 of 3
    Jul 15 2004
    MA
    Is there a current source for RNS-E replacement screens?
    I looked through the archives here and it seems that every previous source no longer exists.
    I have a '192 P unit with a failed backlight. I checked the ribbon cable last night and all traces are good (I even tested them with my DMM) and both ends of the ribbon are fully inserted. Is there a good source for replacements these days?
    Achat S4, Black Q7
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    Consider this as an opportunity to upgrade to gen II Rns-e. Even if you able to source screen, capacitors and possibly other electronic components, and DVD drive are approaching end of life. You can transfer your faceplate to any GenII ***193 unit, as faceplates fully compatible.
    https://www.ebay.com/itm/275890706764?epid=1956920000
    Jul 15 2004
    MA
    That's pretty tempting. Do you know if the knobs can be swapped as well? I'd like to stick with black ones.
    Achat S4, Black Q7
