Results 1 to 8 of 8
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Replacing BCM Question
    I have an '04 B6 with what I'm nearly positive is a bad BCM. My question is if I can't find a new one with a matching code 8E0907279F, in order to use a different one how would I go about reprogramming it to work can that be done in VCDS? or, as another option, is it possible to just swap out all the modules from a different car without any programming?
    I had water intrusion into the cab last time it rained and at first my wipers started running on their own, then they worked fine for a couple of days and now they don't work at all. I've been over everything I can think of, the transmission isn't seized, I tried a different motor, fuses are good, relays are good, the stalk still activates the washer jets so I don't think that is an issue. and there doesn't seem to be any wiring issues.
    I don't currently have access to VCDS or any other real means right now to start testing connections but what I do have is an entire other B6 I can borrow from before I have to bite the bullet and take it somewhere as money is kind of an issue for the time being but I live in a place where it rains a lot and I kind of need the wipers to work on my daily.
    I know this is probably a stupid question to a lot of you. I've just never really been great with electrical work but I still figured I'd ask while I'm still researching. Appreciate any help.
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Even though no one responded, I'll post the solution anyway:
    Pulled the BCM out and it was indeed saturated with water. I took it apart and attempted to dry it out but unfortunately it was done for.
    I pulled the BCM out of my backup car just to try it any way even though it's a different code (8E09027279E) and it fixed everything.
    So at the very least right now for anyone else who ever runs into this problem, if you can't find an 'F' code replacement an 'E' code will work, depending on the options you car may have. the 'E' code replacement fixed everything in my car with the only exceptions being that my rearview mirror doesn't auto dim and the compass doesn't work. it also forces the headlights on at all times while running.
    I suspect the headlight thing is just because the '03 I took the 'E' code out of doesn't have automatic headlights so now that it's in a car that has them they're just forced on because there's nothing to tell the system it's daylight.
    So for posterity's sake, this could be a bandaid for anyone who runs into this issue and doesn't have great access to parts or scrap yards.
    Junior Member One Ring europeein's Avatar
    May 14 2023
    B6 A4, MK3 GTi Cup
    Rhode Island
    Are you referring to the Comfort control module under the driver seat? If so, how did you get that much water under there? That’s like 3” deep. Also if yes, I have a completely different part number on the one I just took out of my 04’
    May 14 2023
    B6 A4, MK3 GTi Cup
    Rhode Island
    Scratch that, I read your first post, you are referring to the Vehicle Electrical Control not comfort.
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    I believe you can recode that module so that those things work like they used to. The pop up menu will tell you how to code it.
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Quote Originally Posted by Cybersombosis View Post
    You can, I know but I don't have VCDS or anything to work with in order to do it.
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Quote Originally Posted by europeein View Post
    There's a few different names all these modules seem to go by. VEC and BCM are the same thing, "body control module" located behind the kick panel under the steering wheel.
    as for the amount of water: this B6 is new to me and I learned the hard way that it has a water intrusion problem from the ECU box, I didn't notice it when I bought the car but the previous owner had the immobilizer deleted and absolutely mangled the ECU box when he took it apart. after getting into it all I noticed he moved all the electrical inside the cab out of the way of it minus that module so it had been in there getting rinsed for who know how long before it gave up the ghost.
    so for the time being I've got a donor one installed and wrapped up until I get a chance to seal up the ECU.
    Feb 27 2011
    Winnipeg
    you're going to have an incorrect vin code but as long as your parts car has the same options the coding should be the same. Coding is based on factory trailer hitch which never was offered in North America, auto headlights with light sensor, xenons or halogens and location for whether you need DRLs or not. E or F you can interchange as long as you don't have auto headlights IIRC.
