So my 13 a5 has been doing this stutter right when you get on the gas, very low rpm. Hot/cold is doesn’t matter. It almost breaks up. Is not throwing any codes, no check engine. I just had my timing chain cover, chain, etc all redone cause of a leak in the chain cover. The euro shop said I wouldn’t worry about it since it’s not throwing a code, my buddy said you have a intake pump under the back seat. Which feeds the high pressure pump and if it’s not delivering it correctly. But I was thinking injector issue, any help would be appreciated
