Results 1 to 11 of 11
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    The New APR Intake System is Here!
    The APR Full Intake System for the MQB / MQB EVO / MQB Ax 1.8T / 2.0T EA888.3 / 3B / 4 / 4B Engine is Here!
    Product Page
    The APR Open Intake System is here for the 2.0T EA888.3/3B engine found in the Volkswagen MK6 Polo GTI (Typ AW) and Audi MK2 A1 (Typ GB)! The system also fits most 1.8T / 2.0T EA888.3 / 3B / 4 / 4B engines found in most MQB, MQB EVO, and MQB Ax platform vehicles making it a perfect low cost option for nearly any setup!
    The APR Open Intake System features a straight through filter design with minimal twists and bends for maximum flow and minimal pressure drop. Our proprietary washable and reusable cotton gauze high flow filter flows 22% more than stock at various depressions, registers less pressure drop at each depression, has 20% more surface area compared to stock, and uses a filter substrate material proven on other APR intake systems proven to provide the necessary filtration to last a lifetime.
    The filter's unique design allows for air to be fed from the front and sides of the filter with minimal restriction due to its shape and size. The outlet of the filter is massive, registering in at 127mm (5"), which has a cross sectional area 260% larger than the stock tube! Air velocity is accelerated through the system as it smoothly transitions to the factory back tube where the system either connects directly to the factory MAF housing, or to our back tube adapter, depending on engine. In either scenario, the transition is simple and clean for a perfect fit while promoting maximum flow.
    The heatshield and inlet pipe is made from a glass filled polypropylene material that acts as an excellent heat deflection barrier to minimize inlet temps compared to no shield at all. The airbox is fed with fresh air from the frontal inlet ducting, rather than the surrounding engine bay, or radiator, keeping the system constantly fed with cool incoming air to satisfy the turbochargers needs under even the most demanding situations. The system literally installs in minutes too as it simply pops into place on the factory mounting pegs! And thanks to the open design, you'll hear the engine and turbocharger putting in work to make maximum power!
    Features:
    • Open Airbox Design
    • Washable and reusable high-flow pleated cotton gauze filter
    • 20% larger than stock filter with frontal inlet and 127mm (5”) outlet
    • 127mm (5”) filter transition is 260% larger than stock
    • Filter outlet stack increases air velocity to maximize flow
    • Filter flows 22% more than stock
    • Minimal twists and bends further maximizes flow
    • Lower pressure drop than stock
    • Less strain on factory components compared to stock
    • Better throttle and turbo response compared to stock
    • Straight through design with no sharp or harsh bends and restrictions
    • Airbox design captures frontal inlet air and reduces suction from engine bay and radiator
    • Enhanced engine and turbocharger sounds
    • Simple and easy install
    • Supports both MAF and non-MAF engines
    • Designed specifically for the Polo GTI / Audi A1
    • Fits most MQB, MQB EVO, and MQB Ax platform vehicles
    • Fits most 1.8T / 2.0T EA888.3 / 3B / 4 / 4B engines
    • TUV approved for the target platform and emissions friendly VIA APR Germany
    Flow Bench Data
    Comparing the factory airbox to the APR airbox, we saw over 22% more CFM at every depression!
    Tests were conducted with the factory MAF in place using the Airbox only.
    Photos
    Product Page
    Fitment
    ROW market design intent:
    • Volkswagen MK6 GTI (AW) – 2.0T EA888.3 / 3B
    • Audi MK2 A1 (BG) – 2.0T EA888.3 / 3B
    Global Engine Fitment Guide:
    • 1.8T EA888.3
    • 2.0T EA888.3 / 3B
    • 2.0T EA888.4 / 4B (LK1, LK2, & LK3)
    ROW market fitment - Also fits the following with the engines listed above. Date ranges and official names will vary from country to country:
    MQB
    o Audi A3 / S3
    o Audi Q2 / SQ2
    o Audi TT / TT-S
    o Seat Leon / Cupra
    o Skoda Octavia / VRS
    o Skoda Superb
    o Volkswagen Arteon
    o Volkswagen Golf
    o Volkswagen Golf Alltrack
    o Volkswagen Golf R
    o Volkswagen Golf Sportback
    o Volkswagen Golf GTI
    o Volkswagen Golf GTI Clubsport
    o Volkswagen Lamando
    o Volkswagen Passat (Non USA) / Magaton
    o Volkswagen Passat (China)
    o Volkswagen Polo GTI
    o Volkswagen Touran
    MQB A0
    o Audi A1
    MQB A1
    o Seat Ateca
    o Cupra Ateca
    o Skoda Karoq
    o Volkswagen Jetta / Sigitar / Vento
    o Volkswagen T-Roc
    o Volkswagen Taos / Tharu
    MQB A2
    o Audi Q3
    o Seat Tarraco
    o Skoda Kodiaq
    o Volkswagen Tayron
    o Volkswagen Tiguan
    o Volkswagen Viloran
    MQB EVO
    o Audi A3 / S3
    o Audi Q6
    o Seat Leon / Cupra
    o Skoda Octavia
    o Volkswagen Golf
    o Volkswagen Golf R
    o Volkswagen Talagon
    o Volkswagen Tavendor
    o Cupra Formentor
    USA Specific
    • 2015-2016 Audi A3 1.8T
    • 2015-2023 Audi A3 2.0T
    • 2015-2023 Audi A3 Quattro 2.0T
    • 2019-2023 Audi Q3 2.0T
    • 2015-2023 Audi S3 2.0T
    • 2016-2022 Audi TT Quattro 2.0T
    • 2016-2022 Audi TTS Quattro 2.0T
    • 2019-2023 Volkswagen Arteon
    • 2015-2018 Volkswagen Golf 1.8T
    • 2017-2019 Volkswagen Golf Alltrack 1.8T
    • 2015-2023 Volkswagen Golf R 2.0T
    • 2015-2029 Volkswagen Golf SportWagen 1.8T
    • 2015-2023 Volkswagen GTI 3.0T
    • 2019-2023 Volkswagen Jetta 2.0T
    • 2019-2023 Volkswagen Tiguan 2.0T
    Please Note: Date ranges and fitment outside of the USA will differ. Vehicles with secondary air injection require CI100020-A.
    Product Page
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Feb 27 2013
    Twin turbo 350Z, Mercedes ML350, Audi Q3 and BMW 535i M sport
    New York
    Do you guys offer a intake system for the 2015 Audi Q3? Cant find it on the website but i see they offer one for the Tiguan of the same year ?
    B7 A4, 6MT, Quattro - Sliver (Sold)
    JHM HPFP upgrade, JHM Test Pipe, JHM Y pipe, B7 S4 exhaust, JHM flywheel and RS4 clutch, GFB DV+, P3 boost gauge, S4 front & Rear brake upgrade, 034 rear sway bar, ST Coilovers, K&N filter, ECS Oil catch can, JHM K04-R Turbo Kit.
    Audi Q3 8U-White
    https://www.youtube.com/channel/UCWU...e_polymer=true
    Aug 23 2008
    Auburn, AL
    The 2015 Q3 is on the old PQ35 platform, which is closer to the MK1 Tiguan.
    https://www.goapr.com/products/engin...5_18t_and_20t/
    The APR intake most likely would mount, but there would probably be a gap between the front of the car and the airbox inlet as I don't know if any of our adapter brackets fit off memory. Basically, if I don't have it listed on the site, I'd personally consider it as requiring a little work to adapt it to the vehicle.
    Feb 27 2013
    New York
    Thanks Arin for the information, That is what i was looking at the only thing that i saw different was there is a vacuum line that goes to the intake on the Q3 that i don't see on the Tiguan setup but does not seem to be a hard modification to add. Please see picture below I guess i will take a leap and order the plastic one as i don't want to mess up a carbon fiber intake.
    Audi Q3 8U-White
    Aug 23 2008
    Auburn, AL
    I noticed that too. It looks like you'd need to tap into the system post filter and add a nipple.
    Established Member Two Rings cmil527's Avatar
    Oct 16 2023
    Old Bridge NJ
    Nice... my mom just got 2024 Q3 i wonder if she would go for an intake lol!
    2024-SQ5-Glacier White/Magna Red-Prem+-Options:S Sport,Nav,Sport Exhaust,BO Pkg & 21'' BO Wheels,Nappa Leather,Audi "S" Beam,Cargo Cover,Black Rings,Audi Guard-Mods:HRE FF10-21X9.5''-Tarmac-255/40 Pirelli P-Zero,20% Side & 35% Windshield Tint,JB4 Map 6 w/Bluetooth,Roar Pedal,034 Turbo Inlet & Trans Mount,AWE IC,Roc Euro Intake,ECS X-Pipe/Res Delete,Badgeskins DRL Kit,TGK Lowering Links,DSG Red CF Paddles+PSB,Maxton Kit w/V2 Lip & Roof Spoiler
    Veteran Member Three Rings PassionForAudi's Avatar
    Aug 10 2016
    4M.5 SQ7, B8.5 A4 (hey, I keep it clean, though!) and 5th gen’ Ram 3500 Limited Mega Cab (DRW).
    Orange County/Inland Empire, C
    Quote Originally Posted by cmil527 View Post
    “Mama once told me NOT to get a tattoo…………… But what mama don’t know won’t hurt her!” - A wise man once stated
    (You don’t give people options, you make them do it!)
    Oct 16 2023
    Old Bridge NJ
    Quote Originally Posted by PassionForAudi View Post
    Lol amen!!
    Feb 27 2013
    New York
    Thanks Arin I placed the order for it so we will see what i can do to get it to fit.
    Audi Q3 8U-White
    Aug 23 2008
    Auburn, AL
    Thank you!
    Feb 27 2013
    New York
    Quote Originally Posted by Arin@APR View Post
    Thank you!
    Got it to fit.
    Audi Q3 8U-White
