Results 1 to 10 of 10
    Senior Member Two Rings ZTTRS's Avatar
    Jul 26 2018
    TEXAS
    Titanium lug bolts recommendations
    Ive seen some good options from USP, Acer, ECS...
    Im not running any spacers and on OEM wheel set up, so just looking for OEM replace, in Black ofc.
    Any recomendations would be greatly appreciated, thanks!
    Veteran Member Three Rings Chaoscreature's Avatar
    May 26 2018
    2018 A3 Quattro, 1995 Porsche 993 C2, 2006 Jetta TDI Special Edition, 1956 Willy CJ5
    Vista, CA
    If you are looking to decrease rotating / un-sprung mass there are better ways to go about it.
    That being said, if ECS make Ti lug nuts, I wouldn't hesitate to bolt them up. Most of their products have been good enough quality.
    "If everything is under control, you're going too slow" - Mario Andretti
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Titanium is an interesting metal. I recommend you don't get Ti lug bolts. Just asking to introduce problems you don't have today with zero benefit
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Dec 25 2004
    Earth
    Acer Racing
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Senior Member Three Rings 8STTRS's Avatar
    Jul 28 2021
    Navarre, Florida
    I'm fairly certain I went with the ones from USP. I've had them on my car for over a year without any issues. It's just a few hundred dollars and when you consider the scheme of things for building a car, it didn't really make or break any decisions. I just had a general rule of thumb--which was if a part comes off of my car and I have an opportunity to upgrade it or use a lighter component in its place, that's what I would do.
    2018 Audi TT RS
    JDY Next Gen 6670 coming soon (shooting for 975-1kwhp on low boost).
    Jul 26 2018
    TEXAS
    Quote Originally Posted by Chaoscreature View Post
    The OEM ones have taken a beating and are rusting up, as ugly as they are, the plastic caps to hide them is also a look I dont like....really the main reason for replace
    Quote Originally Posted by Spinnetti View Post
    Im not too versed in titanium, what do you mean?
    Quote Originally Posted by MikTip View Post
    Acer Racing
    These look great! This might be the route I go
    Jul 26 2018
    TEXAS
    thats a great way to think! USP looks good too, I need them to be black
    Jul 28 2021
    Navarre, Florida
    Quote Originally Posted by ZTTRS View Post
    He's likely referencing the likelihood of the dissimilar metals being in contact with each other and causing corrosion and potential binding. I had titanium lug nuts on my C7 Z06 prior and while some folks will tell you to use anti-seize on them prior to install, another race shop suggested that I simply loosen and retighten the lugs every 6-12 months to ensure they don't corrode and bind. It's so far never been a problem for me, and I do this every six months just to be sure.
    2018 Audi TT RS
    Jul 26 2018
    TEXAS
    Quote Originally Posted by 8STTRS View Post
    thanks for that man, I didnt know that. Ill likey go ACER or USP here shortly and I remove my wheels pretty often so I shouldbe fine. which ones did you go with if you dont mind saying
    Jul 28 2021
    Navarre, Florida
    I honestly don't remember. But I'm fairly certain I purchased these:
    https://www.uspmotorsports.com/produ...-27mm-75017823
    I'd just ask USP to be sure these are the right ones.
    2018 Audi TT RS
