Hi All,
I was driving home from work one day and my EPC light came on with a flashing CEL light. Engine got sluggish and it felt like the car might stall - this is while diving 70 on the highway. Luckly I was at my exit and pulled off, parked the car on the side of off ramp and turned it off. Waited a few minutes and turned the car back on and it seemed ok. Then while driving back to my house the engine started stumbling again, pulled into the driveway and turned it off. Checking the codes this is what came up on my OBDEleven:
Misfire Cyl. 1
Misfire Cyl. 6
Random/Multiple Cylinder Misfire
Cylider 6 - Injector Circuit - Fault Code P020600 (intermittent)
Hide Cylinder - Fault Code P130A00 (intermittent)
I did some research and found a lot of folks pointing to a vacuum leak and a faulty PCV. I started the car up and tried to take off the oil cap and noticed a heavy suction on while trying to remove. I'd put it around 8-10lbs of force to get past the suction. So doing some more researching and decided to order the JHM Billet Crankcase Breather Vent Hose Kit to replace my two PCV lines. Installed and started up the car, cleared the codes and it seemed to be running just fine. I did notice a very low level whistle while the hood was popped but didn't think much on it at the time and was just happy to hear my car running again.
Fastforward a week or so and the same thing happened except while on some side road. Stopped again and this time had a solid CEL light and EPC. Took me a while to slowly get my car home and received the following codes:
Misfire Cyl. 1
Misfire Cyl. 3
Misfire Cyl. 6
I popped the hood and did the oil cap check and noticed it still had a strong suction ~8lbs. This time I paid attention to the whistle and tracked it to the mouth of the driver-side intake. I could hear it coming from one of those tiny holes on the intake and you couldn't hear anything on the passenger side intake. So I started removing the intake sections, removed the box with the filter and the sound moved to the exit of the sleeve coming off the throttle body. Then removed the TB sleeve and whistle was coming from within the TB. I started playing with all the vacuum tubes and couldn't get the noise to change. I also did A LOT of adjusting the JHM PCV system with no change to the whistle or suction on the oil cap.
I came back at it with a smoke test that I rigged up myself. Filled the intake manifold and couldn't spot a leak unfortunately.
At a loss I finally removed the throttle body on the driver side where that whistle is coming to see if there was anything wrong with the gasket and also to get a better view at the vacuum lines around that area. While it was really dirty the gasket looked fine. What I did spot were some gaping seams in the intake manifold inlet. These appear to be seams and not cracks but one or two of them look far from a standard seam and wondering if I found the issue. Not sure how many of you have removed the TB before but if someone has can you take a look at these pics and let me know if what you've seen on your car is similar or not? Also as I suspect someone might ask, I pushed open the passenger side and peered in with a flashlight - the same seam is sharp and not gaping like in these pictures.
Appreciate any insights or feedback on this!
