Results 1 to 7 of 7
    May 27 2023
    California
    Hard downshifts ?
    Hey all.
    Recently picked up a '23 RS5 back in early April. First time owning an Audi, coming from a Golf R. Had a bit of a rough start with it - improperly seated bump stops and then a major one with it needing a full mechatronics unit replacement. Took 4 weeks to get that particular part.
    Got it back yesterday and I've noticed the downshifts while in sport mode or rs1 mode (all sport/dynamic custom settings in rs1 mode) have been very jerky. For example, coming to a slow stop from 40mph to 0 ends up having significant hard downshifts where it noticeably moves you forward.
    I could be applying same brake pressure from 40 to 0 but as it's downshifting, each shift rocks me forward.
    Now when I drove it for the first 3 weeks pre-mechatronics repair this wasn't an issue or noticeable at all. Just incredibly smooth shifting.
    It doesn't do this in normal mode.
    My question for you owners is the harsh downshifts expected behavior or am I running jt back for more warranty repair ?
    Apr 19 2019
    Toronto, Canada
    It's totally normal. The 034 Motorsport transmission mount insert really helps smooth that rough shift (not totally gone but a good reduction).
    https://www.034motorsport.com/034mot...-aluminum.html
    Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
    Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
    May 27 2023
    California
    Quote Originally Posted by Burrcold View Post
    Appreciate the response. I figured it was normal based off it being a performance vehicle and all. I was just off put by it since pre-mechatronics replacement it didn't have the downshift aggression at all.
    Though, that may have been why it needed to be replaced too!
    That insert is definitely something I'll grab.
    Cheers!
    Veteran Member Three Rings B6_Dolphin's Avatar
    Apr 10 2005
    PNW
    Two mods I've already completed on my '23 RS5 Coupe w/Comp Package - 034 Motorsports Strut Brace, and the ECS Tuning Poly Transmission Mount.
    The mount has made the upshifts/downshifts much less jarring, because they are quite aggressive.
    2023 RS5 Coupe - Ascari Blue/Black; Mods: IE A2A IC, 034 Strut Brace, ECS Poly Trans Mount, APR CF Intake, EuroCode FRT & RR STB + Endlinks, DTE Systems PowerControl X & Pedalbox Pedal Tuner, AskCarbon Steering Wheel, ROW Tailights
    2021 SQ5 S/B Prestige - Daytona Gray/Black
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by billb3rt View Post
    Hey all.
    I actually prefer the shifting in non-sport mode. Much smoother. The throttle is sharper in Sport, but the transmission is jerky. I have found it less so when using sport in manual mode. Wish we could keep the throttle response of sport mode and the transmission shift of non-sport, but it is all or none.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Apr 19 2019
    Toronto, Canada
    Quote Originally Posted by VVG View Post
    Try the transmission mount insert, it really makes the shifts smoother in Dynamic.
    Veteran Member Three Rings Dan99's Avatar
    Feb 09 2019
    Chicago Area
    ...Got it back yesterday and I've noticed the downshifts while in sport mode or rs1 mode (all sport/dynamic custom settings in rs1 mode) have been very jerky. For example, coming to a slow stop from 40mph to 0 ends up having significant hard downshifts where it noticeably moves you forward... I could be applying same brake pressure from 40 to 0 but as it's downshifting, each shift rocks me forward...
    I suppose the real question is whether or not your transmission is behaving as intended by Audi. One quick way to check that would be to test drive another 2023 RS5 off the lot and see if it does the same thing. That way you can judge for yourself, and when the service department says it's normal, you compare it with your test drive.
    I have a 2019 RS5, so my experience may be somewhat different. It's the same transmission, but apparently with modified tuning. I drive in Sport all of the time and the only time I ever felt a downshift that moved me forward was just before coming to a complete stop. The transmission would downshift and add to the braking power in a less-than-natural way, but it was around 10 mph, not 40 mph. The 034 transmission mount helped smooth out all of the shifting in my ZF, but the 034 TCU tune also seemed to reduce the effect of those weird downshifts, so it appears to be an issue with the stock TCU tuning.
    But, I would start with a test drive of a new 2023 before jumping to any conclusions. The 2023 programming may just be more aggressive, or you may have a problem. A test drive can help you decide.
