The 034Motorsport High Pressure Fuel Pump Tool is designed to make the disassembly and reassembly of EA888 Gen 3 2.0T & C7/C7.5 S6/S7/S8/RS7 4.0T high pressure fuel pumps a breeze! This tool was designed for ease of use with a 1/2” ratchet drive, making it easier to use than other tools on the market.
Features:
- Custom Tool to Disassemble and Reassemble the EA888 Gen3 and C7 4.0T Fuel Pumps
- Use When Upgrading Your Pumps with the 034Motorsport High Pressure Fuel Pump Piston Upgrade Kit (034-106-6057)
- Machined from Billet 1040 Steel for Strength
- Zinc Plated for Durability and Long Lasting Great Looks
- Dual Hex
- 24mm for Wrench or Socket
- 27mm for Fuel Pump Cap
- 1/2” Ratchet Drive Provision
- Easier to Use Than Others - No Need to Remove the Piston Before Disassembly of the Pump
Check it out Here!
