Results 1 to 24 of 24
Thread: B7 engine help
    Established Member Two Rings stalley's Avatar
    Jun 27 2013
    Kearny NJ
    B7 engine help
    Any help or info/guidance would be greatly appreciated
    I think my cars engine is dead and my cars been sitting for about a year in my backyard. I want to bring it back to life, anyone know where I can get this process started and best bang for buck option. I live in New Jersey.
    Jan 07 2021
    2000 New Beetle, 2007 A4 Cabriolet, 2010 A3 S-Line
    California
    You might want to start with more info on why it was parked in the first place. Why do you think the engine is toast? Mileage, symptoms, you know the basics as we aren’t mind readers.
    In the process of de-beatering a 2007 A4 Cabriolet
    Jun 27 2013
    Kearny NJ
    Lol yeah you’re right
    Well I was driving on the nj turnpike one day after work and all of a sudden I started losing engine power and eventually got stranded on the side of the road, long story short I got it towed to the mechanic and he said based on how the engine was moving when we tried to turn it on he assumes one or more rods are bent but that’s just his opinion I don’t know for sure but I guess he’s right idk? Engine has a little bit over 200k so I’m thinking getting a rebuilt engine or a salvaged engine is a good start just don’t know where I can even get a used engine that would fit my car. It’s a 6 speed 2.0T. I’m willing to spend the money to get it back running maybe one of you audi guros can help me
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Quote Originally Posted by stalley View Post
    Sounds like you’re probably not equipped to troubleshoot this yourself from what i’m reading, no offense. First step would be find a different mechanic that isn’t going to try to start the engine and say “welp, sounds like all your rods are bent!”
    Second step would be to pay said mechanic to fix your car.
    That’s your best and probably only option in this scenario based on your situation as described and based on your troubleshooting abilities and level of resourcefulness.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jan 07 2021
    California
    Getting an engine out of a junkyard is a crapshoot. Even a place like LKQ is a gamble IMO. If you want the cheapest running option I’d start looking for a lowish mileage rust bucket to scavenge the engine from.
    Jun 27 2013
    Kearny NJ
    If I did want to get a another engine where would I start to look for one? Do y’all think someone on this forum might have an engine for sale?
    Feb 15 2016
    Cambridge,Ontario
    ok let's slow down.....everyone is jumping to the solution and we havent even defined the problem..
    1. what is your mechanical aptitude ? are you able to remove the front Inspection panel and see if the timing belt is snapped or stripped ?
    2. are you able to put it in neutral and see if both the Intake and exhaust cams are turning when you turn the crank (19mm I think ) by peering in the oil fill hole ? ( snapped chain ) , or even better, take the valve cover off ?. then at least you might know what you are dealing with. then it just might be a head r and r and have the head sent out for new valves. still cheaper and less work then a suspect new engine from somewhere else .
    rods rarely get bent but a timing chain and tensioner at 200k is right on time to fail.
    if you can do these things you have nothing to lose but your labour and you might learn a thing or 2 along the way.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Mar 25 2015
    Placer County
    Quote Originally Posted by Gowking View Post
    Let’s not enable this guy here… He needs to figure out what is even wrong with his car first.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT, 08 manual Titanium Avant
    frackville, pa US
    100% agree with iceman. A few simple test can get your some answers. More likely the timing belt, or cam chain snapped. As he said, that would be just a head refurb, or swap. Much, much easier and cheaper..
    Even a video of it turning over. Loss of compression has a very familiar sound
    Sent from my LM-V600 using Audizine Forum mobile app
    Jun 27 2013
    Kearny NJ
    I will post up a video as soon as I can so that way it helps. I disconnected my battery so I’ll have to put that back and have my brother record it while I try to turn it on.
    Jan 07 2021
    California
    Easy guys, he asked a question and I answered it with a bit of advice. By no means was I suggesting he go straight to replacing the engine.
    Sep 24 2006
    Audi S4 MB S500
    Georgia
    Assuming you unfortunately had a timing chain snap I have a like new head for sale. This would only be helpful if you know how to put it on. But if you are in need it be willing to sell it for pennies on the dollar. Good luck in your trouble shooting.
    2008 B7 A4 RIP
    2022 CT5 V Blackwing
    2022 F-150 Lariat 3.5 BAP
    Jun 27 2013
    Kearny NJ
    Alright guys I made a really short clip of what it sounds like, if there’s anything else I could focus on let me know…
    Hope this kinda helps…
    https://youtube.com/shorts/R8kFF14Df9c?feature=share
    Junior Member One Ring
    Mar 06 2023
    Minnesota
    Based on the video sounds like you have lost compression. You also have lateral movement on your exhaust cam as it spins around....thats not ideal If you don't want to tackle repairing this, find a good mechanic and they should be able to give you a decent quote. It probably won't be cheap. I just rebuilt my 2.0t and I had about $3,500 into it. I did all the labor, so that $3500 was just parts. Before i decided to rebuilt it myself i had a shop give me a quote of around $5,500. A good re-man head will run you around $1200. And if your rear timing chain broke, which I'm guessing it did since you lost compression which means you have bent intake valves, you will have sent some amount of metal throughout the engine. That's why I did a complete engine rebuild. Hope this helps.
    Jun 27 2013
    Kearny NJ
    Thank you ajluhmann and everyone else. I think ima just do a complete engine rebuild, question is where can I get a refurbished engine?
    Feb 15 2016
    Cambridge,Ontario
    im curious now, definitely no compression, pop that oil cap off and tell us if the intake cam is moving when you crank.
    1976 Yamaha XS 360
    Jan 21 2018
    frackville, pa US
    Imma guess a broken cam.. Lock at the cam sprocket, when hes turning it over.. Pull the VC off, bet you'll find your damage.
    Question is, why did it break? Often seen that happen with loss of oil pressure. Journals get hot, seize up, and crank keeps spinning the cam sprocket.
    You may get away with a new/used head, but id also drop the sump, and go over your oil pump/BS assembly.
    If your paying for labor, a rebuild will be pricey! Be better if ya can find a used engine, but ya still gotta go over all the common failure points before dropping at in. Either way, its gonna cost.
    Im doing a basic refresh on mine soon. Forged rods, rings, bearings, lifters/rockers, etc. Prob only about $1k in parts, but font be paying for labor.
    So ya should dig a little deeper, and then ya can decide what ya wanna do.
    Mar 25 2015
    Placer County
    before anything else I think you should take your valve cover off. it’ll take no more than an hour and you’ll get so much more info on what the culprit could be than you ever could with it on. Whatever the issue is you’re going to need to pull the valve cover regardless, so you’ve got nothing to lose by doing it, and everything to gain.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jun 27 2013
    Kearny NJ
    I got you iceman, ima try to make a better video this weekend or sooner with the oil cap off.
    Jun 27 2013
    Kearny NJ
    Quote Originally Posted by Jayz691 View Post
    Imma guess a broken cam.. Lock at the cam sprocket, when hes turning it over.. Pull the VC off, but you'll find you damage.
    Thanks for the info jay, i’m stuck on if I should just look around for a low mileage engine I could take from another b7 or get the same engine salvaged.. idk if anyone here would know anyone who has one for sale?
    Jun 27 2013
    Kearny NJ
    Quote Originally Posted by Gunnarrrrr View Post
    That sounds like a good idea Gunnar, ima look into how to exactly take it off and or what tools I need to do so… any guidance or info on how to would be greatly appreciated, I’ll try and YouTube it lol
    Feb 15 2016
    Cambridge,Ontario
    taking off the valve cocer is very straight forward,, just take off what you see... take off the coil packs, then take the bolts out of the cover., undo a couple of hoses. . its about as straight forward as it gets.
    1976 Yamaha XS 360
    Mar 25 2015
    Placer County
    whether or not you end up being able to get your valve cover off without any instructions should be the test that confirms whether or not you should be tackling this job further on your own. It’ll be a good aptitude test.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Feb 15 2016
    Cambridge,Ontario
    agreed
    1976 Yamaha XS 360
