Ok, my alternator is bad. Driving home from lunch after church today, I got an alternator fault battery not charging alert, then my car started freaking out, gave me steering system fault, spoiler fault, transmission fault while I was sitting at a light where I had to put it back in park and into drive again.
So I figured I would have enough juice to get home (and luckily I did).
I went to pull codes, and it said it would turn the car off soon in KOEO configuration, I had popped the hood to see if the belt had popped off (it hadn't and why should it) and as I was running VCDS, I noticed a smell, saw some smoke from that area, and immediately turned the car off, hence the abbreviated scan.
My car is a 2013 with 93k miles, was it just time? Or did something I (or someone else did) cause it. Could all of this be one huge coincidence?
These are the things that have been done to the car in the past couple of weeks.
Me:
I installed laser jammers (and by extension, I had to undo that little fuse box under the ECU and run the wires through the firewall). Is there any chance I could have nicked something while I did that? To add to that story, when I was trying to fish the wires through, I pulled the grommit through into the car, and I cut the grommit off and reinstalled it from the outside with all of the wires through the middle as far as I could tell. I don't think I snagged anything, but I cant be 100% sure. I put the jammers in yesterday I had from something else. They are wired up fine and wired on the same fuse as my radar detector, I would think if there were any issues in the wiring, it would have been isolated to that system.
I also installed JHM downpipes and futzed around under the car. I remember seeing some red wires down there, but I don't think I hurt anything, but I could have.
An Indy Shop:
These people had left several under the car panels off or unfastened, so I doubt the work a little.
They replaced the motor mounts, and also the cat pipes. I don't know what all they did or didn't do, my car was in the shop for a while.
Here a list of codes I was able to retrieve is attached. Sorry it won't let me load it up on here.
https://drive.google.com/file/d/1ttQ...ew?usp=sharing
I was thinking along the lines of if a wire got snagged, if it were causing a ground fault in the charging system, it could have placed an undue current draw on the alternator and led to an expedited demise. Also, it could be just a huge coincidence. It is probably close to the end of the road for my battery too, as far as I know it had never been changed.
I will be ordering an alternator, because that is obviously bad.... what else should I be working for?
What exactly is in that fusebox below the ECU anyways. I saw red wires bolted down, wisdom told me not to touch those to anything as they were probably hot wires, so I was careful there. Anyone know where I could get a wiring diagram while we are at it?
I think this is my first alternator failure.... weird huh.
Even my ridiculous 350whp miata I had for 17 years still had the OE alternator on it.... yep it was right at 25 years old and had 260k miles on it when I parted the car out. Went through 3 engines and 5 transmissions and still on the factory alternator.
