Hi Everyone,
New-ish Audi owner and first time poster here. Thanks in advance for your help and time. I have a B7 RS4, and after 5 months of ownership, it's finally thrown it's first warning light. Yesterday afternoon the EPC and Traction Control Lights popped on immediately after mid-corner heavy throttle application with ESP off. Instead of doing what these cars do best and clawing its way out of the corner, it went into limp mode and the EPC and Traction control lights came on. I turned the car off, waited a few minutes, turned it back on, and the lights were gone. Took it for a spirited drive and it drove perfectly. I did pull codes anyway, and here's what came up:
Engine Management:
00289 (P0121) Throttle Position Sensor (G69) Implausible Signal P0121 Not A Plausible Signal - Intermittent
Brake Electronics:
01314 Engine Control Module Read Trouble Codes - Intermittent
Airco:
00819 High Pressure Sensor (G65) Signal Outside Tolerances - Intermittent
I cleared the codes and drove about 25 miles home with no issues. If anyone has any insights or experiences with these codes, I'd very much appreciate your input on what you think might've caused this. My first guess after some research is that the throttle body could be the culprit, but I'd love to hear anyone's input who's more knowledgeable than I am. I plan to just keep driving it and seeing if they pop back up. Also, maybe worth noting: this happened immediately after getting state inspection. I highly doubt this has anything to do with it but it's still a weird coincidence.
Thanks everyone
