Results 1 to 8 of 8
    May 06 2023
    EU
    Camshaft position sensor (G40)
    Hey guys
    I have one weird issue sometimes it pops up error camshaft position sensor and sometimes fine .. But it only comes up when I do colds start in morning or after work, engine cranking quite long. Once or twice already was cranking very long and engine just stalled didn't even started.. and on dash error came up auto start/stop function unavailable.. But when I turn off ignition and start car again it starts normally ...
    Any help appreciated
    Veteran Member Four Rings ReggieNoble's Avatar
    Dec 17 2016
    B5 S4 Avant
    Fl
    Camshaft magnet adjuster on the side of the valve cover.
    Dec 25 2004
    Earth
    Quote Originally Posted by ChatYTB View Post
    Hey guys
    This is on the diesel?
    From the above posted pic of the vcds scan looks to be electrical...connector...wires...corrosion...
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Dec 25 2004
    Earth
    Quote Originally Posted by ReggieNoble View Post
    This is the G40 "Camshaft position sensor": (intake cam position sensor near #4 intake runner)
    The magnetic adjusters are N318(exhaust) & N205(intake)
    Disclaimer: This is based on ChatYTB saying the diesel and petrol engines are the same...
    May 06 2023
    EU
    Quote Originally Posted by MikTip View Post
    MikTip I think u are naive amateur mechanik only
    I did not say petrol and diesel are exactly the same .. I said they are almost same and very similar
    I suggest you to watch this https://youtu.be/aWeqyAxlM2M
    And I knew you typically will show sensor .. As usual sales person or amateur .. You think I don't know that ? That first thing is to change sensor .. I replaced like 3 of them ..
    @ReggieNoble exactly knows what is issue ..
    I think u only messing with audi cars swapping engines weirdly because u bored
    U even showed wrong sensor means u really don't know or have idea
    This is correct one below
    May 06 2023
    EU
    Exactly I was thinking of that ,check this video https://youtu.be/DXvHdmq0reA
    Dec 25 2004
    Earth
    There is no difference between diesel audi a3 and petrol a3 they design is almost identical only difference is that petrol engine has petrol in it with spark plugs and diesel has glow plugs and petrol engine has spark ignition and diesel has compression ignition
    The collant system is exactly same the transmission is exactly the same
    Only engine is petrol
    https://www.audizine.com/forum/showt...1#post14942142
    You wrote "There is no difference between diesel audi a3 and petrol a3 they design is almost identical
    I wrote "same"....
    You win. Your the Great Audi Master Mechanic of the WORLD!
    From now on... ignore all my posts here...cause I am going to ignore yours!
    May 06 2023
    EU
    I wrote "same"....
    that what you think I guess.. instead of laughing and insulting you could /should normally discuss it.. but you choosed make fun of.. 🤷*♂️
