Results 1 to 3 of 3
    Apr 17 2013
    Beitstad, Norway
    2015 C7.5 Allroad - Water in passenger footwell - no sunroof
    Noticed a pool in the passenger footwell today after steady rain over the last week. It's wet up towards the doortrim as seen in the picture, and it seems to be wet in the area above the trim (outside) when opening the door. However - there is no obvious defects on the seal. Seems like the water is entering from another place higher up and ending up there because of the way it's been parked.
    Car has been parked front down in a slight downhill, with a small tilt to the right.
    Photos: https://postimg.cc/gallery/6X8784r
    Roof-rails, front window - any common known issues with theese?
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Need to clean the drain
    18 S6
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Check and clean the drains under the front windshield, likely clogged if they haven't been cleaned in some time. You'll probably need to remove the cowl to get access.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
