Two days ago I was driving home and when I merged onto the freeway I floored it like anyone would, but I noticed that my car would not go past 4k rpm or 60mph.
I limped it home where I found out that at idle it had a really bad choking rhythm indicative of a misfire. As if one of the cylinders wasn't firing at all. I turned it off and went to bed.
I work in a diesel shop so two days later I brought it in to look at it. Scanning codes I got the usual misfire codes and P0016 and P0011 for timing faults (timing too advanced). Did the usual misfire diagnostics and even a compression test to be safe and everything came out good.
My first thoughts were that maybe I skipped timing just barely enough to where it could still run. I pulled idle logs and what I found was a misfire every stroke for cylinder 3, and if I gave it throttle and let it settle back down to idle the constant miss would move to cylinder 2. Probably the VVT just messing with the timing enough to change the miss. Logging timing also found a massive discrepancy between requested and actual. There were no consistent misses on any cylinders under any throttle.
However, things get weird when after turning on and off the car multiple times over the course of 3 hours logging, messing with controllers, and diagnosing. The last time I turned it on the problem fixed itself. The idle was smooth and after logging the idle the misses were all gone and actual timing went back to being similar or the exact same as requested. This only lasted for a little while though as I took it for a 5 mile drive and the timing issue came back around 3 miles in.
Now what could be causing this? My best guess right now is Cam position sensor number 1, Crank position sensor number 2, and VVT solenoid number 3. I don't think it skipped timing anywhere because obviously it went back to normal for a period of time. Also for reference, I had my cam chain and tensioner replaced around 10k miles ago at an Audi specialist shop. I will likely be purchasing a new CPS and throwing that on soon and I will share the results and see where this goes.
Any thoughts? Please anyone feel free to chime in. This isn't a usual problem I see a lot of people have so it would be nice to hear some more opinions.
