The 034Motorsport 4 Bar MAP Sensors are Now Available for EA839 2.9T/3.0T: https://www.034motorsport.com/034mot...2-9t-3-0t.html
The 034Motorsport 4 Bar MAP Sensors are designed to replace the factory 3 Bar MAP sensors on the EA839 2.9T/3.0T engine. These sensors are a required upgrade for 034Motorsport Dynamic+ Stage 3 Software. Included are two 034Motorsport 4 Bar MAP Sensors which plug directly into the OEM harness and are a direct drop-in replacement.
FEATURES:
- 4-Bar MAP Sensors Designed to Replace the Factory 3-Bar MAP Sensors on the EA839 2.9T/3.0T Engines
- Enables Calibrations Above the Factory MAP Sensor 3-Bar Limit
- Specific Software Calibration is Required to Utilize These Sensors
- Manufactured by an OE Supplier to 034Motorsport Specifications
- Sensors Plug Directly into the OE Harness
- Direct Drop-In Replacement of the Stock 3-Bar Sensors
