Results 1 to 3 of 3
    Junior Member Two Rings
    Feb 07 2021
    NORTH JERSEY
    Launching boost?
    When launching my rpms are at approx. 2600
    But boost bar is only about 40 -50% up.
    It fully boosts when the car is moving .
    Is this what everyone else is seeing?
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Yes thats normal. if you were building your max boost pressure at launch then you would just spin tires and not get traction
    if you wanted for whatever reason to increase the amount of boost you are launching with then that needs to be handled by a tuner
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    being APR stage two, it seems the best launch doesn't require much more than that. IIRC, my top launch rpm(4500±?) just makes it fun to hear & experience the burnout (not quicker at all with stock tires)
    2016 S6 - sport - optx- atlas - AE nardo
