Results 1 to 9 of 9
    May 24 2023
    Phoenix, AZ
    Saving Memory When Replacing the Battery
    2018 A6. While changing the battery, can I provide power for memory saving using a 12v source into
    the 12v accessory outlet?
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Quote Originally Posted by mlandau33 View Post
    Anything wrong with the post under the hood??
    May 24 2023
    Phoenix, AZ
    Quote Originally Posted by WatchMeSpend View Post
    I was going to use a 12v output of a lithium ion jumper.
    Mar 19 2019
    Toronto/Ontario
    I've charged the battery under the hood in my A4 through the cigarette lighter to get the car started when the hood was stuck closed. You would have to find a spot where the power is constant because the outlets may not be connected to the battery all the time unless in accessory mode. Went to run my tire pump a few weeks back and the trunk accessory outlet didn't work unless in accessory or the car was running.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Many folk on AZ report that they change their battery on C7 cars without using any trickle charger and do not lose memory (maybe Audi started using NVRAM). Are you sure you need to do this?
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    May 24 2023
    Phoenix, AZ
    Not sure about the non-volatile memory. Being a 2018 (built more than six years ago), I am guessing that the odds are less so. I already have the jump starter, so I figured I'd play it safe. It's the wife's car, so there is no room for messing it up.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Had my battery disconnected for an extended period of time when I did the timing chains. When I turned the car on after repairs it had the correct date and time as well as all my radio presets. No issues at all.
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Unnecessary. Just change battery, you won’t lose anything.
    18 S6
    May 24 2023
    Phoenix, AZ
    Thanks, everyone.
