Thread: A/C issues
    May 21 2023
    Duluth, MN
    A/C issues
    Hey all. I bought my 2016 A4 Avant about a month ago. I live in northern MN (USA), so I haven’t needed to use the A/C till recently. When I turn it on, the two driver’s vents blow pretty cool (more so the one near the center), but all other vents blow warm to hot. VCDS is not showing any codes. Per recommendation, I replaced the A/C pressure switch. This seemed to make the cool air in the driver’s vents slightly cooler, but all other vents are blowing hot. Anyone experience similar issues?
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    Quote Originally Posted by mattlily View Post
    Sounds like a stuck blend door actuator
    May 21 2023
    Duluth, MN
    Quote Originally Posted by apeck240 View Post
    Do you know of a way to verify this? Seems like an expensive thing to guess on.
    Apr 01 2021
    Command with vcds and confirm or just change temp. Unfortunately most answers on the internet will be guesses
    May 21 2023
    Duluth, MN
    Good point. I’ll give this a try. Thank you.
