Results 1 to 6 of 6
    Jun 04 2016
    A
    Query regarding rear brake upgrade options, as I need to replace them.
    Hi All,
    hope everyone is doing well.
    My rotors/discs are warped, its been on the back-burner .... they shudder and its now getting worse. It happens when I brake and I believe its the rear due to no shaking on the steering.
    Time to act so I may as well upgrade the lot, given that I've overcapitalised on the car with the full forged engine rebuild already.
    I have done some reading on Audizine regarding B8.5 A4/S4 upgrades for brakes and so far this is my understanding;
    - S4 B8/B8.5 - Front disc 330mm & rear 310mm.
    - A4 B8/B8.5 2.0T - Front disc 320mm & rear 300mm.
    Question: so confirming that the extra 10mm size difference in rotors will not be compatible with each other?, e.g 330mm + 310mm will not work for the A4 unless calliper change?
    - The best bang for buck upgrade for FRONT is Audi Q5/Porsche Macan as a BBK, they bolt straight up to A4/s4 without the need of caliper carriers.
    Question: this will only allow for 330mm discs, and not any other sizes such as 345mm?
    However, i don't see many (if any) options for the rear brake caliper + disc upgrades out there, what are the options to go larger for the rear? as I'm interested in the 2-peice for the upgrade this time.
    Thanks again, much appreciated.
    Jun 29 2018
    Orlando
    Jun 29 2018
    Orlando
    He discusses brake options here in that video including rear.
    Sent from my Pixel 7 Pro using Audizine Forum mobile app
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    The Macan 4 piston Brembo only comes in 345mm flavor, the Q5 comes in 345mm and 320.
    The S4/S5 rear caliper/carrier use 330x22mm vented rotors vs 300x12mm solid, for this reason you cannot use the stock rear caliper with an S carrier as has often been done in the front.
    Jun 04 2016
    A
    Apologies it's been quite a while.
    Having a company vehicle i've barely driven the vehicle.
    But ill now need to do some servicing to it and revisiting this, apologies in advance for the questions. (I'm a bit rusty in this scene)
    Quote Originally Posted by bastafari View Post
    The confusing thing is that he mainly talks about S4.
    Quote Originally Posted by JLAllroad View Post
    Could you specify which year model Macan brakes bolt on or part number ?
    Upon searching, I can see that the Macan has a two options:
    1.) 4 Pot caliper (i think this is the base model)
    is this a 345mm Front rotor and it can bolt straight onto the B8.5 A4?:
    2.) 6 pot caliper ( I think this is the GTS model)
    would this also be a 345mm front rotor? and can it also bolt straight onto B8.5 A4?:
    Im weighing up options at this stage, theres seems an abundance of wrecker calipers, but the downside with that is that ill have to find someone to both re-powder coat and rebuild them.
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by doublespeeded View Post
    there are numerous threads here and elsewhere discussing it with part #s. The 4-pot Brembo caliper from the Macan/Q5 3.0T/TDI is the one which is a bolt-on for the B8 and uses a 345mm S4 rotor. The 6-pot from the GTS does not work without modification
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
