Results 1 to 16 of 16
    Nov 09 2022
    New England
    Need advice
    Edited
    Jan 29 2017
    B7 RS4, B15 Sentra Spec V
    San Antonio, TX
    That ring land must have been bad from the get go, that thing needs to be pulled and I think the only thing that saved it so far is the rings. I see no indication of the valve contacting the piston.
    Just need a new (or used) piston, hone the cylinder and get new rings. Check the bushing on the rod piston end and new rod bolts...there's something I'm forgetting....
    Nov 21 2012
    BC
    What does the head look like?
    Sent from my motorola one 5G ace using Tapatalk
    2000 S4 - Daily
    1989 MR2 Supercharged (Turboed)
    Veteran Member Three Rings Atomic Avant's Avatar
    Jul 11 2016
    2005 S4 Avant, 2016 Q5
    Ontario, Canada
    Any damage to the head?
    Sent from my NE2215 using Audizine Forum mobile app
    AKA: FlyingNipples
    Nov 09 2022
    New England
    More pics
    bd
    Nov 21 2012
    BC
    Some kind of hard foreign object/debris..
    2000 S4 - Daily
    Jul 11 2016
    Ontario, Canada
    Quote Originally Posted by oasis View Post
    Looks like it might have been a part of a spark plug or hardware.
    AKA: FlyingNipples
    Veteran Member Four Rings Rol-co's Avatar
    Dec 12 2020
    Europe (NL)
    Maybe broken valve stem end? you can see if you take the valves out.
    Only milk and juice come in two liters, "05 S4 B7 tipt Avant phantomschwarz/schwarz
    Nov 09 2022
    New England
    db
    Jul 11 2016
    Ontario, Canada
    Quote Originally Posted by addicted2avants View Post
    I guess I'm lucky it didn't do any more damage. Since I'm this deep into the engine my plan is to get another (used) piston, new rings and con rod bearings for all 8 cylinders and re-hone all 8. That way I'm good to go for a while. Thanks for the advice!
    Might as well build and boost!
    AKA: FlyingNipples
    Nov 09 2022
    New England
    bd
    Dec 12 2020
    Europe (NL)
    Yeah maybe. I'll be doing the valve stem seals in the next few days and will inspect the valves in that cylinder.
    What triggered you to do the stem seals? If i look at the piston there is no excessive oil consumption?
    Nov 09 2022
    New England
    bd
    Senior Member Three Rings AlexB6S4's Avatar
    Nov 07 2019
    Oakland Park, FL
    Need advice - 1 piston slightly damaged
    I would replace the piston as it may come further apart. The lower compression is most likely from a valve or two in that chamber leaking at the seat since there is high probability of a valve closing on whatever the object was and trapping it on the seat leaving a indent. We have a great rebuild program if you need help.
    Chief Shenanigans Officer @ AMTuned LLC
    Nov 09 2022
    New England
    bd
    Nov 07 2019
    Oakland Park, FL
    Thanks Alex. I was just looking into your head rebuild program and might go that route. Will be buying the rings and a few other things from you too if I decide to dive in and do the bottom end refresh.
    Spunds good. I have like 100+ used stock pistons in a bin that we can match a weight and OD on if you need.
