Results 1 to 7 of 7
    Established Member Two Rings Liberty0rDe4th's Avatar
    Mar 28 2022
    usa
    Items to replace. Bushings, mounts, and such
    I have an 07' a4 with low miles.(50k) She's in great shape but definitely getting old. I imagine some items need to be replaced purely because of age. Could "you people" help me come up with a list of potential items. Some links wouldn't be bad either.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Had my serpentine belt, transmission mount, and front struts replaced at 50K so if you haven't done it, consider it soon.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Mar 28 2022
    usa
    I can dig it......
    •Serpentine belt
    •Transmission mount (manual)?
    •Front struts
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    Cam follower.
    Sent from my SM-G781U1 using Audizine Forum mobile app
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Mar 28 2022
    usa
    Cam follower below the high pressure fuel pump was changed out in order to make the fast fast yeehaw yakety smackity zip Zawie! Along with the HPFP of course.
    Excellent thought thank you.
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    suspension are pretty strong on those cars.
    Mine has 93k miles, stock shocks ( sline) , on H&R springs, and daily on probably the worst road in n/a.
    Still no leaks, no double bounce due to a empty shock. Also, links and arms bushing are still in good condition, no cracks nor clunks. I did a full inspection last weekend due to a clunck, turns out was the BBK-17z coming loose.
    - cam follower
    - fuel filer ( easy)
    -spark plug
    - alignment
    - change all liquids , including power steering, brake, coolant, transmission (go OEM oil!), rear diff
    - timing belt and serpentine.
    - carbon clean
    - check if your engine mount are leaking. Mine leaks for years, no issue since it was small. Now on poly one from CTS
    - if you plan to do a long trip, maybe the coolant flange at the rear.
    Jul 25 2019
    Charlottesville, VA
    This may be of help:
    https://www.audizine.com/forum/showt...-amp-Solutions
    I hear you on the low mileage thing. Mine is an '06 (3.2 manual) with 65K miles on it currently. Should be up for sale in a few weeks, though, as I am getting a B8 w/ 30K on it.
    Eric
    2015 A4 2.0T Quattro
