Originally Posted by
sage0607
I datalogged iats are fine. I have the plug and play harness for my coolant pump. Temps are actually quite a bit lower than with cwa50 so its definitely working
Sent from my SM-G960U using
Audizine Forum mobile app
I understand you have that harness, I’m saying even with that harness, it won’t run right on B8.5’s and it’ll throw the code. Anyway, seems yours falls under the working state, so you shouldn’t have any soft codes for the pump.
All the videos I’m seeing shows that with IE, CC in the Off position turns the fans On. This may have been your issue if you keep it Off as one normally would.
