Results 1 to 19 of 19
    Senior Member Two Rings ZTTRS's Avatar
    Jul 26 2018
    TEXAS
    Brake Pads recommendations pls
    OEM originals set lasted 26k, with over 100 passes at the drag strip, roll racing and spirited driving. No actual track time, autoX, HPDEs or anything like that. Thats no longer my interest, continuing my current course of actions I was rather pleased with the OEM pads, only grip was wanting a bit more initial bite. Ive read about 10-15 threads and have some good ideas but some of you guys are way more ambitious in the Braking game than I want lol Im really just looking for an OEM + aftermarket pad, rotors look great, if you have any suggestion please lmk! thanks in advance!
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Porterfield R4-S, made in USA, great street pad
    https://porterfield-brakes.com/searc...ufacturer=7444
    Stage 1 more than you RS3
    Jul 26 2018
    TEXAS
    thanks man, never heard of these guys, but definately willing to try them out.
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    Quote Originally Posted by ZTTRS View Post
    Porterfield is popular. I did not heard of them until I started doing road courses and finding out how many people actually uses that brand. Take a look at Hawk brakes and read about their temperature vs pedal pressure chart, it is interesting.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Sep 27 2020
    Golf TDI
    San Diego
    Carbotech 1521 pads are another option.
    2019 TT RS - S2E85 034 Motorsport - If you're gonna go, you gotta whoa!
    Jul 26 2018
    TEXAS
    awesome thanks everyone, I went with Porterfield R4-S. Will report back on impressions
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    Ferodo DS 2500, good compromise between road and track demand
    2020 TT- RS
    ex 2018 TTS
    Jul 26 2018
    TEXAS
    Porterfield R4-S:
    Definitely the Brake pad I was looking for, Much more braking power than stock pads, actually quite surprising especially when you lay on them hard. Also has a very linear feel, excellent for modulation! Quiet, great price, built in wear sensor...Over all a Win
    Feb 06 2012
    Allentown, PA
    Porterfield R4-S:
    Good to hear!
    Jul 26 2018
    TEXAS
    Quote Originally Posted by o1turbo30v View Post
    Good to hear!
    thanks for the recommendation!
    Senior Member Three Rings sleepy_rs3's Avatar
    Mar 29 2021
    New York, NY
    Have you used the Porterfield R4-S on front brakes for over 5k miles? Mine started knocking in the calipers after 5k, they worked fine but the noise bothered me so I swapped them out...maybe defective or out of spec? I still run the R4-S on my rears, no problem.
    2019 Glacier White RS3 | Unitronic Stage 2 ECU & TCU | Unitronic Downpipe, Intercooler, & 4" Turbo Inlet | CTS 4" pipe to stock airbox | 034 intake heat shield | DSC Sport Controller | Tyrolsport Deadset Subframe Kit | 034 Street Density dogbone kit | Valentine 1 Gen 2 Radar Detector with JBV1 app
    Feb 06 2012
    Allentown, PA
    Quote Originally Posted by sleepy_rs3 View Post
    20k miles on the front Porterfields, O issues
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    What is the dust like?
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Feb 06 2012
    Allentown, PA
    Quote Originally Posted by redline380 View Post
    nothing noticeable until maybe 5 days of daily driving, even then its like a very light grey, nothing like the OE Brembos, dead silent and easy on the rotors so far, remaining pad material measure 5-6mm, so maybe get another 10k out of them, mostly daily use, with a handful of Track Night America events
    Jul 26 2018
    TEXAS
    wanted to give a 3 month Mini review check in on these...
    These pads are fkn awesome,
    Now that I have had time to really dig into them, they are worth every penny. Precise controlled braking, very lineral feel, and virtually no dust. When you lay hard on the pedal its baffleing how great they are. I did the brake fluid also with BG dot4 Will be buying again
    Aug 29 2017
    Tucson, AZ
    That is excellent to hear. I had Carbotech 1521 with no success. I never felt an improvement over stock and the only time that I took my RS3 to a small 1400 yard 13 turn road course the car ran out of brakes twice bad!!! I atribuye the pedal going to the floor due to the stockfish brake fluid which was just freshly serviced. The next time around I will consider the Porterfields based on your feedback and username 01turbo30v and I will also consider the Hawks because I used them on other cars and they are phenomenal too.
    at 3100ft elevation
    Jul 26 2018
    TEXAS
    I think you will be very pleased, although I dont run road courses, auto X or hpde anymore and with this car, my experience with these pads has been just drag strip and fun on the streets, roll racing that kinda thing. To be perfectly honest It feels like these pads barely even broke a sweat
    Junior Member Two Rings
    Dec 10 2022
    8V RS3 - 1M - 958.1 CT
    QA
    I'm due for a brake job. I will definitely check these instead of OEMs.
    Btw, are you on OEM rotors?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by S3DUDE View Post
    Ya know, I have carbotech too and have not been impressed. They aren't bad just not great.
    Sent from my SM-G965U1 using Tapatalk
    2000 S4- Working?
