Results 1 to 21 of 21
    Aug 07 2022
    Eagle, Co
    source for coolant hose from crossover pipe to T fitting
    Anybody have a source for this hose? I believe the part number is 8E0 121 107 D.
    May 10 2018
    MA
    gettable part for me, but it's not listed as a B5 part - double check and lmk if I can help
    Aug 07 2022
    Eagle, Co
    I may not have the correct part number. I'm looking for the coolant hose that goes from the metal fitting on the crossover pipe between the heads (on back of motor) to the T fitting at the coolant reservoir. Thanks RMode.
    May 10 2018
    MA
    Quote Originally Posted by Hmh800 View Post
    Aug 07 2022
    Eagle, Co
    yes
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    May 10 2018
    MA
    yes
    I’ll pm you
    Oct 12 2018
    B5 S4 Avant 2.7t 6MT
    I just installed the do88 silicone hose kit. It is 100% complete and the hose angles fit OEM like. If you install silicone hoses use the wider band clamps for silicone.
    AliExpress and do88 look the same from pictures.
    Sent from my Pixel 7 using Audizine Forum mobile app
    AKA: gjweyman
    Oct 12 2018
    AKA: gjweyman
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    What really needs to be asked is ; are the heater core hoses available in Germany. Doubtful.
    But this will do for now.
    image uploading site
    Aug 07 2022
    Eagle, Co
    Thanks guys- I’m not looking to replace all of the coolant hoses as I’ve already sourced OEM replacements for most of them. It’s surprising to me that the hose I’m talking about ( 1/4” ish from crossover pipe behind heads to t on the reservoir hose from upper radiator) is NLA from Audi. Seems like one of the hoses prone to failure. I guess they all are though at this point.
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    I’m in the same situation. I have found a lot more obscure hoses than this one.
    Mar 24 2016
    01 Noggy S4 09 VW CC AWD 3.6L
    westchester ny
    Same here. I've basically bough all OEM coolant hose but I am looking for the complete T section hose. Wish Do88 would sell just that hose.
    May 10 2018
    MA
    Quote Originally Posted by wstpride92 View Post
    Which one exactly? The upper rad hose?
    The problem with silicone for coolant is often, you experience some loss due to evaporation. This is why the OEM’s all do rubber. For a Motorsport application, absolutely. Fitment can also be a challenge depending on the brand, as trimming etc is often needed. I’ve experienced it first hands on all sorts of cars - audi and otherwise.
    May 10 2018
    MA
    Quote Originally Posted by bmwpower603 View Post
    I believe THETuner does them. It’s a dead # for Audi as far as I know, worldwide
    Would be a nice thing to do an all metal core with braided hose and dry break quick disconnects…..hmmm….the gears are turning :)
    Dec 04 2012
    Arlington VA
    Quote Originally Posted by SideMirror View Post
    Any specific examples of clamps that would work well on silicone? My primary concern that silicone is so slippery. I was thinking turbosmart, like these https://www.amazon.com/Turbosmart-TS.../dp/B004PPX3D2
    May 10 2018
    MA
    Quote Originally Posted by V1nny View Post
    I have these throughout my car now. But their sizing, due to the inner/outer coupler design of the clamp, starts at 1.12inches, fully closed
    The clamps are by Murray:
    https://www.murraycorp.com/turbo-sea...tension-clamps
    But the Turbosmart ones are ultimately easier to source.
    Oct 12 2018
    I used Gates Silicone clamps from Rock Auto over 1/2 wide and smooth inside.
    Attachment 304339
    AKA: gjweyman
    Oct 12 2018
    I should clarify that the clamps used were a combination of single ear wider band and the Gates Silicone
    AKA: gjweyman
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    For the cooling couplers, I saw some metal ones 'Aluminum quick connects' mentioned in the C5 section at post 550 of https://www.audizine.com/forum/showt...-Street/page14 with the pictures of the couplings being shown below. I'm not sure where they were ordered from, but just wanted to mention them. - Jim
    Attachment 303705
    Attachment 303706
    Senior Member Three Rings Hiduke73's Avatar
    Nov 24 2015
    Detroit
    Quote Originally Posted by Calif_Kid View Post
    I got some of those from Amazon for about $7 a piece. But after reading more on them I decided to not use them because multiple people complained about them leaking. I ended up get new oem ones for not much more and no leaks
