The Billet Aluminum DSG Breather Catch Can, Volkswagen & Audi MQB DQ250/DQ381 is Now Available from 034Motorsport: https://www.034motorsport.com/034mot...250-dq381.html
The 034Motorsport Billet Aluminum DSG Breather Catch Can for DQ250 & DQ381 equipped MQB Volkswagens and Audis replaces the tiny OE plastic vent and prevents transmission fluid from being forced out and splashing around the engine bay. Any transmission fluid that is collected in the catch can drain back into the transmission. Improve the appearance of your MQB’s engine bay by installing this beautiful billet catch can and eliminating unsightly oil stains.
The body of the catch can is CNC milled from 6061-T6 billet aluminum and black anodized for a durable and stealthy finish. Internally, a stainless steel baffle plate prevents transmission oil from escaping the system. External mounting brackets are powder coated to prevent corrosion and enhance appearance. The OEM plastic vent hose is replaced with an 8mm I.D. silicone vent hose while retaining the OE connector at the transmission. Finally, the DSG Catch Can utilizes stock mounting points, which makes for an easy installation with no drilling or cutting necessary.
Fitment:
- Audi A3 2015-2020 8V/8V.5 2.0 TFSI
- Audi S3 2015-2020 8V/8V.5 2.0 TFSI
- VW GLI 2018+ Mk7 2.0 TSI Gen3
- VW Golf 2015-2020 Mk7/MkV7.5 1.8T Gen3
- VW Golf SportWagen 2015-2020 MkV7/MkV7.5 1.8T Gen3
- VW Golf Alltrack 2015-2020 MkV7/MkV7.5 1.8T Gen3
- VW Golf R 2015-2019 Mk7/Mk7.5 2.0 TSI Gen 3
- VW GTI 2015-2020 Mk7 2.0T Gen3
Available Now: https://www.034motorsport.com/034mot...250-dq381.html
