I'm going to try to be as detailed as possible.
Currently got myself a B7 Audi 2.0T from someone who sold it at a cheap price that did not start. After I got the car and installed a new battery I found the same issue and found there was no compression in the cylinders. Doing ALOT of research on here and the internet, I found this is usually a problem with the timing chain/belt breaking so I decided to tear the engine apart.
While tearing the car apart, I found the timing belt is still intact but yes the timing chain was snapped in half with the tensioner in pieces all around the engine.
So I was expecting bent valves and possibly piston damage however I got a weird sight. After pulling the cylinder head, I found all the valves still intact with the cams in okay condition.
I turned each cam using a wrench with no problem and the valves extended out and sealed back in again with no issue. I also did the water test where I poured water on the cylinder head and no water leaked out (this test was a bit annoying because when one set of valves went in, the next in the sequence was already out, not sure if this is normal)
I also checked the pistons and I can't see any visible damage and they were all still tightly in the bores.
My question is am I maybe testing this head incorrectly? This seems a bit strange that there isn't a single bent valve.
Pics:
https://imgur.com/a/Wq5mpSD
