    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    WTB: cheap/damaged engine harness
    Looking to buy a cheap engine harness. Poor condition is fine all I need is the Ecu connectors, body plugs and grommet that goes into engine bay. Can be cut after grommet if someone wanted to keep the engine connectors for spares.
    Thanks
    PJ
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    I have 2 spare BEL harnesses if you want one. Not sure if you need an APB or not. I'm across the country tho so shipping would be a thing.
    Nov 13 2018
    Ocean city NJ
    Doesn’t matter BEL/APB, manual or auto.
    You can cut it after the grommet and will probably fit in a medium flat rate box. Shoot me a PM with what you’re thinking price wise.
    Established Member Two Rings Euroheadache's Avatar
    Feb 28 2020
    B5 s4
    Long Island
    Quote Originally Posted by Silverex View Post
    Do you still need it ? I have a bunch . I’m on Long Island . Lemme know
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    I have a somewhat damaged BEL harness as well sitting around, ECU connections and the rubber boot/sleeve thing appear undamaged. lmk
