My ac button will not stay illuminated once pressed although the hvac will blow air but only hot air. I assume I messed something up i tried running the potentiometer & flap alignment, compressor run-in/cooling check, and address lookup/initiation for flap motors. I searched and could not find a solution I did replace the ac pressure switch (G395) just to see if that was it but I don't want to throw anymore parts at it. and totally unrelated and this issue was before but I do not get power to either of the black fuse panels on the passenger or drivers side. Also I do know there is a fault for a convertible top not sure why and how to get rid of it.
Monday,01,May,2023,16:14:37:00227
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WAUFFAFL1BA073856 License Plate: 123456
Mileage: 129930km-80734mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72
77
VIN: WAUFFAFL1BA073856 Mileage: 129930km-80734miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AD HW: 8K2 907 115 D
Component: 2.0l R4/4V TF X19 0003
Revision: E1X19--- CVN: AA0E3A55
Coding: 0104010A290F0160
Shop #: WSC 04919 000 00000
ASAM Dataset: EV_ECM20TFS0118K2907115AD 001006
ROD: EV_ECM20TFS0118K2907115AD.rod
VCID: 71BFD786812914B2F05-8024
VINID: 9D195659159C0524401C320518614783A8
3 Faults Found:
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [047] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 129937 km
Date: 2010.05.01
Time: 15:09:57
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 99 °C
Intake air temperature: 69 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.345 V
Unlearning counter according OBD: 40
4710 - No Communications with Airbag Control Module
U0151 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 129937 km
Date: 2010.05.01
Time: 15:09:57
4714 - Steering Column Control Module
U0212 00 [047] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 129937 km
Date: 2010.05.01
Time: 15:09:58
Readiness: 1110 0100
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8K0 927 158 K HW: 0BK 927 156 N
Component: 0BK 20TFSIUSA H08 0008
Revision: --H08--- CVN: BE706779
Coding: 001112
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMAL551211 001013
ROD: EV_TCMAL551211_001.rod
VCID: 3E253CBA80F7BBCA3D7-806A
2 Faults Found:
12553 - Steering Column Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 129937 km
Date: 2010.05.01
Time: 15:09:57
Voltage terminal 30: 12.369 V
Engine RPM: 0 /min
Status data bus communication diagnostic interface-State Deashboard received: not received
Status data bus communication diagnostic interface-State ECM received: not received
Status data bus communication diagnostic interface-State ESP received: not received
Status data bus communication diagnostic interface-State Gateway received: not received
Status data bus communication diagnostic interface-State Parking Brake received: not received
Status data bus communication diagnostic interface-State Steering Angle received: not received
Status data bus communication diagnostic interface-State Steering Assist received: not received
12561 - No Communications with Steering Angle Sender (G85)
U0126 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 129937 km
Date: 2010.05.01
Time: 15:09:57
Engine RPM: 0 /min
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 1D0508
Shop #: WSC 12345 123 02311
VCID: 025D884AB40F1F2A19F-8056
2 Faults Found:
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:21:18
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0280
Hex Value: 0x0031
Hex Value: 0x319C
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:21:18
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0280
Hex Value: 0x0032
Hex Value: 0x029C
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H04 0430
Revision: 00002001
Coding: 090100
VCID: 76B5E49AE8C7338A257-8022
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H50 0071
Serial number: 0510000059291010
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2310000038454014
No fault code found.
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01011120100084
Coding: 64042000
Shop #: WSC 06325 123 12345
VCID: 00598242BA030D3A0FB-8054
7 Faults Found:
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:45:21
03023 - Running-in Requirement
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:45:21
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:45:21
Freeze Frame:
Temperature: 35.0°C
Voltage: 12.70 V
Output: 4 W
Output: 0 W
Temperature: 37.0°C
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:45:21
01592 - Air Quality Sensor (G238)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:45:21
Freeze Frame:
Temperature: 35.0°C
00712 - Right Footwell Flap Positioning Motor (V109)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:45:34
Freeze Frame:
Voltage: 12.80 V
Temperature: 35.0°C
Temperature: 35.0°C
Count: 12922
Count: 11452
Bin. Bits: 01000000
Bin. Bits: 00000000
Time: 27.00 s
00713 - Centre Left Vent Positioning Motor (V110)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:45:49
Freeze Frame:
Voltage: 12.60 V
Temperature: 35.0°C
Temperature: 35.0°C
Count: 0
Count: 13117
Bin. Bits: 01000000
Bin. Bits: 00000000
Time: 0.00 s
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000698367
Coding: 26000091003CAF010000080300003D0D0F1C52080201016100 0001
VCID: 3C2136B2966BA9DA133-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 261010 H06 0070
Serial number: SWF10100260601
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11123544
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000002010100959
6 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:00
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:00
02258 - Door Opener Transmitter
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:00
03456 - Control Module for Left Cabin Heater
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:00
00830 - Convertible Top Control Module (J256)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:00
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372UAF0000Y
Coding: 000030
Shop #: WSC 12345 123 12345
VCID: 44D14E52EE9BD11A6B3-8010
Component: E221 - MFL H02 0010
2 Faults Found:
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:53
Freeze Frame:
(no units): 44.0
Text: 2C8BFFFFFFFF00C0FF
RPM: 0
Raw, Index/Key Err.: 255 255 000
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:53
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 950 H HW: 8K0 920 950 H
Component: KOMBIINSTR. H20 0258
Revision: 00100000 Serial number: EIL74MNAA
Coding: 8B5709000201D705020001
VCID: 34311E92BE3B619ADB3-8060
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G10A09842F
Coding: 00C303
VCID: 015F8746B1090432005-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 10002F39251010
1 Fault Found:
00576 - Terminal 15
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 6
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:10:03
Freeze Frame:
Bin. Bits: 10110
Voltage: 12.40 V
Count: 7
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020302
VCID: 392F2FA699599CF2085-806C
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C03204000410001
VCID: 53F37D0E1BF546A2E29-8006
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0137323048
Coding: 0106073A00FA440480B0013200000001
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000320562
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS039 H06 0041
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:53
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:57
00218 - Humidity Sensor (G355)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:57
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOC.clb
Part No SW: 8T0 035 223 AR HW: 8T0 035 223 AJ
Component: DSP Prem H19 0320
Revision: 00019001 Serial number: 34803000300100
Coding: 0203010302
Shop #: WSC 05111 444 83889
VCID: 7EA5FCBAC0F77BCA7D7-802A
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
Coding: 011C03205200410001
VCID: 52FD780A24EF4FAAE9F-8006
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000650641
Shop #: WSC 00000 000 00000
2 Faults Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:53
Freeze Frame:
Voltage: 12.50 V
Count: 67
Speed: 0.0 km/h
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
00576 - Terminal 15
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 4
Fault Frequency: 9
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:09:53
Freeze Frame:
Voltage: 12.50 V
Count: 48
Speed: 0.0 km/h
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 392F2FA695599CF2085-806C
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000009 Serial number: AUZ5Z6J1487761
Coding: 0403000200018D034359070800
VCID: 46D5545AD8A7E30A757-8012
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 31
Mileage: 129937 km
Time Indication: 0
Date: 2010.05.01
Time: 15:10:03
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1401
Coding: 010C03204000210001
VCID: 56F5841A0807538A057-8002
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H06 1401
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 336 E HW: 8T0 862 336 E
Component: FSE_256x BT H42 0650
Revision: 00000000 Serial number: 00000005096869
Coding: 0010370
VCID: 3D273BB68171A0D224D-8068
End----(Elapsed Time: 01:44, VBatt start/end: 12.4V/12.4V. VIgn 0.1V)------
