Results 1 to 11 of 11
    Dec 12 2021
    2008 Audi A4 2.0T
    Minnesota
    Question Intermittent vibration while braking at high speeds (50+ mph)
    I replaced all 4 rotors and brake pads about a year ago, just to preface that it *shouldn't* be worn-out brakes or rotors, but for some reason every once in a while my A7 will vibrate slightly while braking at high speeds. Sometimes it is more noticeable than others, but it typically goes away once I drop below 40mph or so. Has anyone experienced this before, or have any suggestions on what might be causing it? I can't recall whether or not it was doing this before I changed brakes/rotors.
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Did it start immediately after replacing? Did you properly bed the brakes after replacement?
    At first thought, it sounds like you might have sticky guide pins. Warped rotors will likely vibrate/pulsate all the time, no matter the speed.
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Jun 19 2020
    Summerfield, FL
    What kind a mileage is on your Olympic ride ...?
    2015 Audi S4 (totaled )
    2017 Audi S6 Wickedly quick | Prestige w/ Black Optic | H&R sway Bars |Eurocode Alu Kreuz Drivetrain Stabilizer | 034 transmission and differential inserts | SRM driveshaft carrier bearing | SRM shorty intakes w/ RS7 airbox | APR ECU stage 1 and TCU | APR (non-res) catback | Giro Disc Front rotors w/ EBC Yellow pads │ 034 2 piece rear rotors w/ Hawk HPS 5.0
    Dec 12 2021
    2008 Audi A4 2.0T
    Minnesota
    Quote Originally Posted by MattyMarkey View Post
    Now that I think about it, I believe it did start relatively quickly after I replaced them, because I remember taking the wheels off to check the carriage bolts to make sure they weren't backing out. It is definitely getting more frequent now though. I did bed them, but honestly, I had never done it before so I have no idea if I did it correctly or not... Guide pins actually make a lot of sense, I will take some time this weekend to inspect those and regrease them. Thanks!
    Quote Originally Posted by Optimus247 View Post
    I just passed 111k. I bought it late 2021 with about 95k, the only work that I have done since owning is the brakes and rotors. Haven't had any other issues besides this, and it really isn't that bad, just want to catch it before it possibly gets worse.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    There is no guarantee that you did not buy a warped or bent rotor when you swapped the pads and rotors. No guarantee that you might have unintentionally got something under the rotor when you tightened it all down. No guarantees that you did not unintentionally warped a pad or a rotor in the break in process as well. Almost always when you feel a vibration under braking conditions it’s a bad pad or a warped rotor. Depending on the brand of rotors they might just be prone to warping.
    Dec 12 2021
    2008 Audi A4 2.0T
    Minnesota
    Quote Originally Posted by Valpo A7 View Post
    I understand that completely. The only thing that has confused me, and led me to believe there isn't anything physically wrong with the pads or rotors is that it doesn't happen every time I drive the car. One day it will be totally fine and brake smoothly, the next day it will pulsate/vibrate while braking at highway speeds. I went with Akebono ceramic pads and Zimmerman rotors, visually the rotors appear to be fine and wearing properly, but I have not taken them off to inspect or anything. I will dig into it this weekend and regrease the guide pins and everything just to be safe.
    Jun 19 2018
    NH
    Quote Originally Posted by bakler5 View Post
    Knowing that it doesn't happen every day and/or all the time, that could also be a compromised brake line, or master cylinder. Check brake fluid levels too
    Nov 27 2018
    Valparaiso, IN
    I have read plenty of times about a collapsed brake hose but only experienced it once. For me the hose passed fluid to allow the brake to apply but then acted like a check valve which did not allow the brake to release. Shook like a mother ******.
    Dec 12 2021
    2008 Audi A4 2.0T
    Minnesota
    Yeah this doesn't shake bad at all. I don't know how to describe it, but it's not even bad enough to make any noise or anything. At its worst, it's like driving on a crappy road or something.
    Dec 26 2022
    Kitchener/Ontario
    To make sure just indicate your rotors and you will find out for sure . To me you have a bad rotor causing pulsation.
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    I had brakes less than a year old and the above happened - it was warped brakes. If you feel it in your foot when you brake its the fronts, if your ass twerks its the rears
    Daily -2015 Audi A7 Prestige| 20% rear & 35% front 3M Ceramic IR tints|Custom Alcantara Starlight Headliner|
    Music, Real Estate, and Audi
