Results 1 to 4 of 4
    Nov 15 2019
    2008 Audi a4 2.0t
    Ottawa/Ontario/Canada
    Swapping s4 3.0 engine from b8.5 to b8 platform help
    Hi, I'm looking for abit help with some knowledge on finishing up my s4 3.0 engine swap. We put the 2013 B8.5 s4 3.0 engine in my 2011 B8 s4 swap is complete but stuck with crank position sensor code that won't clear. Just waiting to get exact code and will update post. Was hoping someone would have an idea or had done similar before ? Can't find much on this swap, thanks
    Feb 16 2019
    miami, fl
    are you able to switch the sensor over from the b8 to the b8.5 block? no expert but that may work?
    Nov 15 2019
    2008 Audi a4 2.0t
    Quote Originally Posted by wrxkyle View Post
    One is a 2 pin other is a 3 pin sensor
    Nov 15 2019
    2008 Audi a4 2.0t
    pretty much all day yesterday to try and figure out why we kept getting a code for the crank and the position of the pick up on the crack is off by a few mm from this engine to the old one The ECM thinks TDC is at one point and it's off so it gives us a code for the crank .
