Results 1 to 2 of 2
    Junior Member One Ring
    Apr 08 2023
    2009 Subaru Impreza
    BC
    S5 B9 Spark Plug Question
    Does anyone know which spark plug is used for cylinder 6?
    Senior Member Two Rings ccssid's Avatar
    Jul 03 2011
    michigan
    is this what you are looking for ?
    Correct. Cylinder #1 is ALWAYS at the front of the engine. For the 12V V6, #1 is on the right...
    side (passenger), with #2 and #3 following on the same side. Cylinder #4 is located at the front, on the left side (driver's side) of the engine, followed by #5 and #6. The firing order per the Bentley manual (and the label on the coil pack) is 1-4-3-6-2-5. TDC means #1 is at TDC. Since there are 6 cylinders, each piston is positioned at 60 degree intervals (360/6 = 60). So, the exhaust cam lobe for #1 should be approaching the exhaust valve lifter when #1 piston is at TDC.
    2011 S4 prestige. Imola 6mt.
