Results 1 to 15 of 15
    Junior Member Two Rings mikepal's Avatar
    Feb 26 2023
    Charlotte, NC
    Spacer Recommendation
    Good morning everyone,
    Happy Saturday!
    I’m looking for wheel spacer recommendations for my 2018 RS3 with stock wheels.
    It has the mag ride and I’ll be installing Eibach pro lowering springs in the next few days. I’ll be keeping the stock wheels (as honestly I love the way they look) but would like to get more of a flushed look.
    Im looking to get some brand/sizing recommendations.
    Thank you!!
    Junior Member Two Rings Asharp's Avatar
    Nov 25 2019
    2019 RS3 Glacier White | 2021 SQ5 Mythos Black
    Lakeland, FL
    10mm-15mm depending on how low you go with suspension. I personally ran 11mm STM on mine as I didn't want poke. Anything more than 11mm you will see some poke. EMD sells a flush 10mm kit also.
    https://stmtuned.com/products/stm-11...-audi-2017-rs3
    https://www.emdauto.com/products/emd...32140349931608
    2019 RS3 - Glacier White
    Feb 26 2023
    Charlotte, NC
    Thank you for your response!! I’ll check these out.
    Sep 27 2020
    Livermore,CA
    If you post in the 8v wheel thread, it may already be at the first post
    Sent from my SM-S901U using Tapatalk
    Feb 26 2023
    Charlotte, NC
    Thank you!
    I’ll go with the 10mm spacers.
    One more dumb question. What’s the max size tire (width) can I run on the stock rims. I’m honestly just looking for visual improvements but don’t want it an an expense of functionality.
    Thank you
    Senior Member Three Rings Cool_Breeze's Avatar
    Feb 22 2020
    San Jose, Ca
    Quote Originally Posted by mikepal View Post
    Thank you!
    Thank you
    I started with 10 in front, then went to 12. 15mm in rear. 034 lowering springs, camber plates with magride and stock wheels.
    Many folks are running 265 tires with no issues. 275 is possible with minor modifications.
    Feb 26 2023
    Charlotte, NC
    Quote Originally Posted by Cool_Breeze View Post
    Thank you!
    Senior Member Two Rings M3_Dylan's Avatar
    Aug 10 2018
    8V RS3, E46 M3, B8.5 S4
    Columbus, Ohio
    Sorry to jack your thread but any recommendations for a 245 square set on aftermarket 9 x 19" wheels lowered on EMD springs? My guess is between 5-10mm
    E46 M3 : Steel grey/6speed. BSpec tune. 19" Anthracite Apex Arc 8's (profile 3). Ground Control Coilovers. Euro headers, Custom section 1, Grouppe M section 3. E60 sort shifter. 19x9.5 ET22 on 245s in the front 19x10.5 ET22 on 275s in the rear
    8V RS3 : Mythos Black/Dynamic+/ CCB's. DS1 E85 tuned by Darin, APR 4" turbo inlet & Intake, 980cc port injectors,EMD Suspension Kit
    B8.5 S4 : Moonlight blue/DSG. KW Coilovers. Luft Technic Intake. EPL Stage 2 ECU/TCU tune. EPL single supercharger pulley.
    Veteran Member Three Rings 0000 RS5's Avatar
    Jul 13 2015
    Quote Originally Posted by M3_Dylan View Post
    What is the offset of these aftermarket wheels? You shouldn’t need any spacers if you bought the correct wheel.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Thank you!
    Thank you
    Stock wheels came in 2 different setups, 4-19x8’s et42 or 2-19x8.5et46 front and 2-19x8et42 rear. The max recommended tire size for a 8” inch wide wheel is a 245, and for the 8.5” inch wide wheel 255. Lots of guys on here are running 245/35 on all 4 corners
    Stage 1 more than you RS3
    Aug 10 2018
    Columbus, Ohio
    Quote Originally Posted by 0000 RS5 View Post
    +42. They are BBS CI-Rs. I'm currently running a similar spec wheel VMR 801s but switching to the BBS in a few weeks. The fitment is fine but personally, I like a really aggressive stance. I believe I will need at least a 3mm spacer in the front to clear the CCBs but I could be wrong.
    Feb 26 2023
    Charlotte, NC
    Does anyone have pics they can share of their RS3 lowered with spacers on stock wheels? I know this may be a tough ask since the stock wheels are generally not a fan favorite . I personally do like them. I found a couple on google but wanted to see some member setups.
    Thank you!!
    Junior Member One Ring
    Jan 23 2019
    Colorado Springs, Co
    Word of warning, many national tire shops won’t touch your car if they have large spacers. I’d double check with your tire shop of choice first to make sure you’re not buying yourself an upkeep headache where you have to haul in loose wheels to get new tires and balanced
    Jul 09 2020
    Michigan
    Quote Originally Posted by Mr. View Post
    Agreed! I have a Jeep Wrangler lifted with nice Spyder Trax wheel spacers and just tried taking to a shop 2 weeks ago to have my back brakes looked at. They wouldn't even pull it into the shop because it has spacers.
    Feb 26 2023
    Charlotte, NC
    Thank you both for the input! Yeah I can totally see that being a problem and I would need to remove them for any type of maintenance. From the shop’s perspective I’m sure they had cases where they reinstalled them and now they’re on the hook for anything related to them. Honestly I’m a little on the fence of even putting them on because in my old M3 I had minor vibration at higher speeds after installation.
