Results 1 to 2 of 2
    Junior Member One Ring
    Apr 13 2023
    Driver door sag - howto fix?
    2013 Q7. Driver door is sagged at the handle side by about 1/8 to 3/16" when closed
    Hinges seem to not have much play up and down.
    Whats the best approach to adjust? remove drivers kick panel and move fuse box to get to lower hinge bolts?
    Established Member Two Rings RAUDIRS6's Avatar
    Dec 02 2013
    18 RS7P, 14 Q7 TDI
    Lusby, MD
    I just did this 2 days ago with 2 washers, my floor jack, and a torx bit with 1/4" mini ratchet. It took less than 10 minutes, probably under 5.
    Place the vehicle on level ground.
    Open the door fully.
    Place a piece of wood between the jack pad and the door bottom.
    Jack up until it barely holds the weight.
    Loosen both bolts. (Don't remove yet)
    Remove one bolt and place the washer between the door and the hinge.
    Reinstall the bolt, but do not tighten yet.
    Repeat for the second bolt.
    Tighten both.
    Lower jack.
    Test.
    You may need to adjust the thickness of the washers.
    Here is a link to the ratchet I used to fit in the spot.
    https://www.harborfreight.com/lockin...ni+ratchet+set
    There are more refined ways to do this. (More money, more work)
    Here is a video with options, and it's pretty funny. (Not mine)
    https://www.youtube.com/watch?v=CvDJIuflNB8
    Sent from my SM-S918U using Tapatalk
    2018 RS7 Performance (Nardo)(DS1 Mod Stage 2, JHM TCU, ECS Intake/Inlets, CWA-100, ARM DP w/ HF Cats, ECS 2.75" Valved Exhaust, 40T E-Sensor w/Bypass & Lines, 034M HPFP, Forge BOVs, JHM T&D Inserts, 034M Tunnel Brace)
    2014 Q7 TDI (RSNav)
    2004 S4 Avant 6MT
    2003 RS6 (6MT Conversion Project)
    2002 Passat Wagon
    1998 Passat Sedan ($1250 Budget Build Project)
    2000 New Beetle
