Results 1 to 4 of 4
Thread: Broken injector
    Junior Member One Ring AB8's Avatar
    May 13 2022
    Uppsala, Sweden
    Broken injector
    Hi, i got a big problem. My Audi 2.0TFSIq 2011 needed new injectors, three of the injectors was pretty easy to get out. Last one (cyl 4) was stuck. Eventually i got it out but the tip of the injector is still stuck. I dont know what to do. Any suggestion how to get it out?
    Best regards
    AB8, Sweden
    Jul 16 2018
    Atlanta
    Very odd. If it's that wedged in, I doubt you can get it out by pulling. You'll want to make sure that piston is low in the cylinder and then have to punch it through into the cylinder and then lift it out through the spark plug hole would be my guess. I'd probably use a punch that's the diameter of the hole so it pushes the whole fragment, rather than a narrow punch that'll just break through the injector holes screen.
    I'm assuming the hole the injector sits in is not tapered so that the fragment can pass into the cylinder. If it has to come out the way the rest of the injector came out, I think you're removing the head.
    You might want to ask this in the B8 A4 forum. Lot of people with experience with the EA888 Gen2 engine there; don't know if they ever look at this forum.
    Veteran Member Four Rings boomtime's Avatar
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    I used a vacuum when i did my injectors to remove any debris that fell into the cylinders as a precaution. I wouldnt try to push the injector tip into the cylinderunless your ok to pull the cylinder head. You can try pushing air pressure into that cylinder thru the spark plug hole and spray penetrating oil down the injector hole. Then vacuum the injector well.
    Otherwise you will probably have to pull the head. Let us know what happens!
    The eventual supremacy of reason.
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
    Jul 16 2018
    Atlanta
