Hello all, I've done some digging and still cant determine the correct route to go on this. About a year ago I replaced my battery (with OEM) and ever since I've gotten the traction control warning light on. Occasionally when driving the throttle will cut out and the car will immediately start hard braking and make a grinding noise, when this happens the traction control light flashes. The only way to get around this is to restart the car. I scanned it and have a P1653 - Please check DTC Memory of ABS controller. I went ahead and replaced the brake light sensor but that doesn't appear to have solved the solution. My next bet would be a wheel sensor but how do I determine which one? Worse case is it seems I may need a new ABS controller module which will run around $2k.
Any help or ideas on this would be greatly appreciated.
