Results 1 to 13 of 13
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    How to PWM your brushed EFK
    Installed a EFK about a year ago and wasn’t really happy with it for my setup. I use a low temp thermostat and normal running temp is around 178. Run a Derale 2speed fan, only on low, since high was a bit much. In the summer heat/traffic/worst conditions it’d get up to 210+ and in winters I’d have to unplug it to maintain temp.
    So after going down the rabbit hole and realizing all the different options I came up with a setup that costs about a 100$, not including fan/wiring, and allows to PWM the fan’s speed according to coolant temp.
    Main components are:
    Mitsu Fan Controller: Got mine with connectors for $25 on eBay. Didn’t want to use the pigtails but finding the terminals was a pain. After a bunch of research/trail and error I found them on corsa-tech
    Small ones
    https://www.corsa-technic.com/item.p...bvJ8WbLJ7vjomY
    Large ones
    https://www.corsa-technic.com/item.p...6XKvqr9OVe1O_M
    The key part of the fan power control module is converting the puny signal from the processor into high power control of one or two fans and allows soft start.
    Tons of info on controller..aka rabbit hole
    https://ls1tech.com/forums/forced-in...ispreloading=1
    For a processor I looked into the Arduino route but didn’t want to figure out the coding and don’t think it would last in a daily driver environment long term.
    Then found this
    https://www.ebay.com/itm/143561646769
    This allows me to use the stock temp sensor, set a low temp for fan to turn on at 25%, high at 100%, and vary the speed between according to temp.
    I’ve only tested it out but wanted to make the post while everything is still fresh for me. I’ll report back after it’s fully installed and dialed in. So far I have it turning on at 175 and by 200f it’s at full speed and seems to work perfectly!
    Only other parts needed is fan, fuse, relay, and wiring.
    Here’s some pictures of a wiring diagram and how I had it mocked up
    Alil box I got to enclose the processor and wiring
    Nov 13 2018
    Ocean city NJ
    Reserved
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Nice work and good write up.
    May 10 2018
    MA
    awesome work on this! So much nicer of a setup.
    Veteran Member Three Rings mjmatos's Avatar
    Apr 29 2014
    Long Island, NY
    Damn this is sick! Great work
    Current
    2001 B5 S4 Sil | ASP Stg 3 | RS6 K04 | Rosten Rods | AWE SMIC| RS4 Engine and Trans Mounts | AMD Stg 3+ | CM SMFW | StopTECH BBK | ASP DP + Exhaust | Tein SS Coilovers
    2001 B5 S4 BB | Blake tuned | E85 | SRM K24 Hybrid | SRM v3 IC | Full SSAC DP + Exhaust | 034 Motor Mounts | CM FX400 | 17z BBK | BC Coils | Wallbro 450
    R.I.P
    2005 B6 A4 1.8TQM | REVO Stg 2| RNS-E | B7 S4 Brakes | ST Coilovers
    2001.5 B5 A4 1.8TQM | Stg 3 | GTRS Elim | Meth
    May 10 2018
    MA
    Quote Originally Posted by Silverex View Post
    Reserved
    next let's do the fuel pump :)
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by RMode View Post
    I did just hardwire/relay my fuel pump and wasn’t going do a write up since that info is out there. It is kinda spread out between a few threads, so if there’s interest I can do a quick write up on hardwiring fuel pump.
    Feb 23 2010
    Emmaus Pa
    I'm going to see how my temps do this summer. I only have the stock electric fans and no clutch fan. But I also have a CSF rad and no AC condenser to block it so temps tend to stay in line pretty well. If it starts to creep up ever, I'm going to follow this write up. I'm almost hoping it does bc this looks sort of fun lol.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    May 10 2018
    MA
    I want pwm :)
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by CELison View Post
    Guessing you don’t drive it on the hottest days with no AC? Cause honestly, unless I was sitting in traffic I got away without running a EFK in summer but since it’s a daily I threw one in and obviously help level out temps. I do think the EFK helps with heat soak/IATs but hard to replicate identical conditions to say for sure.
    I want pwm :)
    Sorry but I have no plans going down that road. Lol. Pretty sure you could use the same hardware. The guy on eBay is really good about answering questions if that’s an endeavor you’d like to explore.
    May 10 2018
    MA
    I should probably leave well enough alone, but I like trying new stuff :)
    Nov 13 2018
    Ocean city NJ
    Wanted to update this after running the setup for over a month. Its been working great and normally runs right around 178. Real test was when I got stuck in traffic on the Schuylkill while it was 85f and it never got above 195. Only times I’ve seen it break 200 is on a hot start and it immediately drops under that before I even start moving. I have zero complaints and highly suggest going this route if you want more control over your EFK.
    Nov 13 2018
    Ocean city NJ
    Had a few guys tell me my diagram sucks, hopefully this one is little less confusing.
