Results 1 to 7 of 7
    Mar 20 2023
    South Korea
    Is there any way to lower the ride with lowering links without error code?
    Hi,
    I lowered the car with the airmatic lowering link as I saw a lot of people here use that link.
    When the car is lowered by 5mm lower than the original one(based on link height), the error code doesn't appear but it doesn't have the slammed look that I'd like.
    When I shorten it more than 5mm, error code appears when I drive on the freeway (above 80km/h).
    What can I do to lower the car as much as I want without the error code? Can someone help? :)
    Thank you!
    Mar 20 2023
    South Korea
    I have 2016 Audi S6 with air suspension btw
    Mar 11 2007
    Colorado Springs
    You have the links adjusted too short, the car is too low and that's why you're getting the fault code. If that "slammed look" is what you're after, you'll need to "air it out." I don't believe the links will get it done.
    2022 Q8 S line Prestige Stock
    2012 A7 OEM Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    ^ this. Too low. It states right in the instructions “do not lower/shorten more than 9mm”. You shortened them 10mm
    Best way to do it is lower 5-7mm MAX, then use VCDS to fine tune lowering it
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Senior Member Three Rings mrdouble99's Avatar
    Mar 31 2018
    Montreal
    Quote Originally Posted by MattyMarkey View Post
    He's not saying he went 10mm, he say that when he go lower than 5mm he's getting the fault.
    Mythos Black Metallic 2018 Audi S6 current
    Moonlight blue 2015 Audi S6 sold
    Senior Member Four Rings THCarpenter's Avatar
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    I wonder if someone adjusted your settings in VCDS/OBD11 before you and you are now working through that as well
    2016 S6 Mythos Black / B&O, Cold Weather, Drivers Assistance, Black Optics
    2016 S6 Mythos Black / Sport, Cold Weather, Drivers Assistance, Black Optics, Night Vision
    "How to spend a shitload of money and still be slow, the THCarpenter story." - sepheroth86
    Jun 19 2018
    NH
    Quote Originally Posted by mrdouble99 View Post
    Ahhh thank you, I can now read it correctly lol
