Results 1 to 13 of 13
    Veteran Member Four Rings LionKing's Avatar
    Mar 09 2017
    2009 A6 Avant - 5.2L V10 Swapped, 2013 S4 Backroads Warrior
    MD
    3.0T parts for sale
    Cross posting from C6 A6 classifieds. these motors share alot of parts, mounting points are different but overall the same. Figured get some more exposure here to get this engine parted out. From what I do know TRANS WILL NOT WORK IN A B8/B8.5.
    Cylinder 5 decided it was time to go. Spark plug fouled out and fuel washed the cylinder... rings tore up the cylinder wall verified with my boroscope so I'm moving on from the 3.0 but keeping the shell...
    That being said, all parts listed are good, unless otherwise noted. All parts are DC/Metro area local, and willing to drive a little(1.5 hrs) or ship if needed as long as shipping is covered by the buyer. Engine and trans have 125k original miles in total. Moving on to a different power plant. Prices are OBO.
    Parts for sale :
    - SC complete with stock pulley, cores(used), sensors, and throttle body $SOLD
    - Black valve covers with recently replaced gaskets (20k miles) $SOLD
    - Yellow Coil Packs and conduit covers with 20k miles (Done by Vast AZ) $SOLD
    - Heads $250 ea
    - Engine block (If you want it, Cyl 5 has 0psi due to rings/cyl wall) $300
    - PCV/Water Pump/Thermostat all latest revision (20k miles, can send part numbers, FCP purchase) $SOLD
    - Injectors (set, 125k miles) $100
    - ECM with full engine harness (Stage 2 JHM) $600 (400 without harness)
    - Transmission (Fluid and Filter done 20k miles ago, with Stage 2 JHM TCU tune) $600
    - 192mm CTS Crank pulley with belt $275
    - JHM Engine snub Mount (C6 specific)
    $100
    - JHM Hx for B8/B8.5 and C7/C7.5 (Silver Quad pass) $425
    Sent from my Pixel 6 using Audizine Forum mobile app
    "Exhaust Gases go in the turbocharger and spin it, witchcraft happens, and you go faster"
    Mar 09 2017
    MD
    Picture of the engine bay is best I can do for now. Can update pictures after engine is pulled and is separated from the car. Can take more pictures as requested while engine/Trans are still installed.Audizine%20Forum-865417011_510x384.jpg
    Mar 09 2017
    MD
    Bumping this
    Mar 09 2017
    MD
    Bump
    Junior Member Two Rings
    Oct 08 2021
    San Diego, CA
    I see the super charger is black, did you have it ported at one point or only painted?
    Mar 09 2017
    MD
    Quote Originally Posted by Ngb5050 View Post
    It's sold, but it was a light port. Just a smooth out
    Mar 09 2017
    MD
    Bumping! Still Available for sale!
    JHM B8/B8.5/C7/C7.5 Heat exchanger - Silver
    CTS 192mm Crank pulley for 3.0T
    JHM C6.5 Front Snub Mount
    C6.5 3.0T Custom Intake Tubing
    3.0T Heads
    C6.5 Transmission - JHM Tuned stage 2
    C6.5 Front Axles
    C6.5 Rear Diff
    JHM Stage 2 ECM
    Misc. On Engine Accesories
    All parts are OBO. See main post for pricing!
    Mar 09 2017
    MD
    Bumping
    Jul 18 2022
    Nj
    Interested in the heat exchanger
    Feb 09 2018
    1991 240sx, 2008 E90 M3
    NoVA
    Injectors still available? Part No.? I'm local in the DC area. Thanks!
    2013 S4, 6MT, Sport diff, B&O, Carbon Atlas inlays | GIAC dual pulley, AWE 57mm SC pulley, Fluidampr 183mm crank pulley, 034 intake, APR heat exchanger, Southbend clutch, Extended slave, CR-15 brace, 35% tint
    RIP 2006 A4 2.0t Avant, 6MT | 034 mounts, RSB, Full suspension, Bushings, Coilovers, Custom headlights, 034 intake, GFB DV+, Carbon wrapped interior trim, iPad Pro dash
    Mar 09 2017
    MD
    Quote Originally Posted by Asteve55 View Post
    Heat exchanger still for sale. PXL_20230711_144648892.jpgPXL_20230711_144622345.jpgPXL_20230711_144633314.jpgPXL_20230711_144600225.jpg
    Mar 09 2017
    MD
    Quote Originally Posted by isfalex View Post
    Injectors are still Available. I need to pull them off to get a part number for you. Give me a day or so
    Feb 09 2018
    NoVA
    Quote Originally Posted by LionKing View Post
    All good that works! Thanks!
