Results 1 to 4 of 4
Hybrid View
    Apr 11 2023
    Austin
    Can anyone help me identify this component?
    I was cleaning out the leaves and debris in the void that is under the plastic shroud by the cabin air intake near the firewall on the passenger side.
    I found this 'sensor' just sitting in that valley. Does anyone recognize it? I'm not even sure what terms to use to search.
    Tia
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    It is the Air quality sensor for the HVAC system. Expensive to replace. Should mount onto the side of the Air Intake for the HVAC, mount must have broken and it fell down. It is supposed to sense pollutants in the air and kick the system into an air recirculation mode until it senses cleaner air again.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Apr 11 2023
    Austin
    Quote Originally Posted by hahnmgh63 View Post
    - - - Updated - - -
    Quote Originally Posted by Smac770 View Post
    Clips into the edge of the grid over the top of the duct to the fresh air intake, item 13:
    https://www.ilcats.ru/audi/?function...35&language=en
    https://www.audiworld.com/forums/q5-.../#post25208820
    must be a RHD vehicle, but you get the idea.
    Thank you!
    Jul 16 2018
    Atlanta
