Results 1 to 39 of 39
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Replacement Fuel Injection Harness for 2000-2005 Audi A4 1.8T cars.
    Pricing is as follows:
    EV1 Harness for Stock Injectors
    $130 shipped in the USA – DM to purchase directly
    $160 shipped Internationally – DM to purchase directly
    EV6/EV14 Harness for Big Injectors
    $150 shipped in the USA – DM to purchase directly
    $180 shipped Internationally – DM to purchase directly
    If you've been grappling with frustrating misfires caused by faulty injector wiring, look no further.
    This revolutionary harness is meticulously engineered to address the common issue of frayed harnesses disrupting the smooth operation of your engine components.
    With the integrated Cam Position Sensor and wiring, this harness offers a comprehensive solution to ensure your engine runs flawlessly, especially in tuned builds.
    Designed to endure the extreme temperatures and demands of 1.8T VAG engines, our 18AWG XL High Temp Resistant Wiring with Heat Shrink covering, guarantees unparalleled durability. Experience the peace of mind that comes with knowing your engine components are operating at their best.
    If you're a performance enthusiast seeking optimal engine functionality or simply wish to enhance the reliability of your vehicle, this Fuel Injector Wiring Harness is the ultimate fix for you. Don't let faulty injector wiring hold you back any longer - equip your engine with our innovative solution and unleash its true potential!
    At the heart of this innovation lies the Deutsch and Bosch EV1 connectors on our Stock Injector Harness and USCAR EV6/EV14 connectors on our Big Injector Harness, known for their unparalleled reliability and durability, even in the harshest of environments. Say goodbye to worries about loose connections or unreliable electrical pathways – our harness is designed to keep your engine running at its peak performance.
    Don't let faulty injector wiring hold you back any longer – invest in our advanced solution and unlock the full potential of your vehicle's performance!
    Includes comprehensive easy to follow installation instructions.
    Installation takes approximately 1 hour
    EV6/EV14 Harness for Bosch 550cc injectors now available for order
    Fits ALL Audi A4 B5 & B6 1.8T models. Sedan, Avant and Cabrio
    2000, 2001, 2002, 2003, 2004 and 2005
    Two of the common problems on classic 2002-2005 Audi A4 1.8T cars is the Ignition/Coil Pack harness and the fuel injection harness. Over time, the wire insulation on the connectors will deteriorate and expose the wires causing engine misfires. While there are several options for replacing the ignition/coil pack harness, this is currently the only available option for replacing the damaged fuel injection harness. Replacement harness is made from larger 18 gauge AWG High Temp wire. Harness also replaces Camshaft Position Sensor connector as well.
    Kit includes following:
    Replacement Fuel Injection Harness with integrated Cam Position Sensor Connector.
    Harness uses high quality waterproof Deutsch Connectors
    Female Deutsch connector and terminals - Crimper and wire strippers required (not included)
    INSTALLATION INSTRUCTIONS WILL BE SENT IN .pdf FORMAT VIA EMAIL AFTER PURCHASE
    EV1 Harness for stock injectors
    EV6/EV14 Harness for Bosch 550cc injectors - installed in car:
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    May 22 2007
    Santa Monica CA
    I currently have two kits assembled and ready to go. Here's some feedback from eBay:
    Excellent Seller , Fast Shipping , Seller very help with installation instructions , wiring harness very well made , highly recommended , 5*********
    Excellent seller, very helpful, and willing to provide advice. Item shipped quickly, arrived on time, and with no issues. Would 100% purchase from this seller again.
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    Bump for member/seller. Came in handy as my harness went bad on both cars. One has been installed and issue resolved. Still need time to install 2nd.
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by 1.8Turbo4me! View Post
    Thanks for the bump! Got one left, not sure when the next batch will happen.
    Sep 24 2016
    Calgary, AB
    Quote Originally Posted by AvantNoir View Post
    Ttt
    Would you be able to build me one with different connectors? I have bosch 550cc injectors and want to get rid of the connector adaptors for a lower profile look and simpler setup
    03 A4 1.8t Quattro Avant Tip
    Revo Stage 3 / GTX2867r / 550cc / APR Manifold / IE Rods / ER Comp. FMIC / AWE Exhaust / TIP-Chip, etc etc.
    May 22 2007
    Santa Monica CA
    Absolutely. PM me and we can discuss it. Or you can contact me on IG, @cbarz - I'm usually there more than here.
    Sep 24 2016
    Calgary, AB
    pm sent on IG. thanks!
    May 22 2007
    Santa Monica CA
    Some more feedback:
    This is a very well made solution to a very common problem. The instructions were very thorough and this was overall a great buy. Helped clean up the engine bay a ton
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Looks nice. I had no idea you were making these. A few weeks ago I bought the parts needed to make the same harness. Looks like I used the same connector to connect to the main harness.
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by Kevin C View Post
    Thanks! Yeah, whole thing kinda took off. I've made over 40 of these at this point. No one else makes a kit for this.
    Sep 24 2016
    Calgary, AB
    I'm super Happy with the one AvantNoir built for me, and the instructions were simple/straightforward to follow. This Solved my misfires, simplified my setup and cleaned up my engine bay quite a bit. Extra bonus was that he installed rubber boots that fit over the EV14/USCAR locking connectors so that it looks oem when installed. I've never used a Deutsch connector before last week, and i have to say these are soo much simpler than some alternatives out there. No fiddling with little rubber grommets/seals, and simple to take apart later if needed. Photos of the installed harness can be found on my IG account here: CLICKY
    I had misfires on Cylinders 1 & 2, as well as an Ignition Circuit open fault ( P0301,P0302, P1358 ) that were pretty persistent. I had already replaced 3 of my coil pack connectors, and 3 of my fuel injector connectors over the past 4 years, so my wiring harnesses were pretty brittle/unsightly already. On top of that i'm running 550cc injectors which need a different connector and i didn't like how much the adaptors pushed my wiring harness up toward the hood and caused clearance issues for the cylinder 1 injector harness. I contemplated just depinning the harness and swapping injector connectors, but my harness already looked like crap so i figured better to replace the whole thing in one shot.
    Replacing the Coil pack harness helped eliminated the Ignition Circuit Open fault code, but it wasn't until i replaced the injector harness a week later that i was able to eliminate the Misfires on 1 & 2.
    The Only suggestion I have for anyone else is make damn sure you have a quality set of wire strippers and the correct crimper on hand. AvantNoir was kind enough to include links in his instructions to affordable/correct tools on amazon if you or your friends didn't already have your own. These wires are small, and stripping them with cheap pair of wire strippers will not work well in your favor.
    Veteran Member Four Rings Ozone510's Avatar
    Feb 15 2016
    Audi A4 B8 Avant 2.0T, Audi A4 B7 2.0T SOLD, Audi TT 8J Cabriolet VR6 DSG
    Hayward, California, USA
    Pmd
    Sent from my Pixel 7 Pro using Audizine Forum mobile app
    May 22 2007
    Santa Monica CA
    May 22 2007
    Santa Monica CA
    bumpo
    Feb 15 2016
    Getting mine installed this week, hopefully it clears out all my weird misfires codes that seemingly have no "fix".
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by Ozone510 View Post
    May 22 2007
    Santa Monica CA
    May 22 2007
    Santa Monica CA
    eBay link for EV1 harness has been updated. Just restocked on connectors.
    DM me or contact me on IG if you need an EV6/EV14 harness.
    Feb 15 2016
    Swapped mine last week, works great, solved many of the misfire codes I had, though some remained from other unrelated issues. I did take these photos from under the boots in my injectors though for those that are curious:PXL_20230809_010226100.jpgPXL_20230809_010205889.jpgPXL_20230809_010155201.jpgPXL_20230809_010105425.jpgPXL_20230809_010132151.jpg
    May 22 2007
    Santa Monica CA
    Nice!
    May 22 2007
    Santa Monica CA
    Got a few harnesses available to ship
    Have 2 EV6/EV14 Big Injector Harnesses for $150 shipped in the US.
    And 1 EV1 stock injector harness for $125 shipped in the US.
    This is the last EV1 harness I have available for a while as the EV1 connectors are on backorder .
    I also have a brand new crimp tool I accidentally bought for $19.00, will sell for $15
    International shipping available for $20
    Account Terminated One Ring
    Sep 05 2023
    U.S
    Still available?
    May 22 2007
    Santa Monica CA
    Just wanted to let everyone know I’ll have fuel injection parts beginning of next week. Should be able to ship by next Friday 11/03.
    If anyone wants to preorder and send me a 50% deposit, I’ll offer a $15 discount.
    Harness price will be $110 for the EV1 or $135 for the EV6/EV14 shipped in the US.
    Otherwise price is $125 for the EV1 or $150 for the EV6/EV14 once the connectors arrive.
    International shipping available for additional $20
    May 22 2007
    Santa Monica CA
    Who needs an Audi 1.8T fuel injection harness? My connector order just arrived! Going to start putting these things together now. Should have a couple ready to ship by Monday. Since the order arrived much sooner than I anticipated, I will extend the offer for the $15 discount until Sunday at midnight. You will need to order before then and pay in full in order to take advantage of the discount.
    Attachment 317798
    Junior Member One Ring
    Oct 05 2023
    CeeAyy
    I’d buy a set if you had a 386cc bundle. Lol. Look like a quality piece. Free bump.
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by driveway View Post
    Plenty of places you can get injectors at good price. Furthermore, Bosch 386cc injectors are no longer available. You need to consider a different option.
    That said,
    I can do a set of new Bosch 550cc injectors and an EV6/EV14 Harness for $360 shipped.
    or
    New Bosch 440cc injectors and EV1 harness for $260 shipped.
    or
    New Bosch 380cc injectors and EV1 Harness for $275 shipped
    May 22 2007
    Santa Monica CA
    Year End Cleanout Sale.
    All 2023 Harnesses must go to make room for the 2024 Harnesses!
    Right now until 12/31/2023 at 11:59PM PST
    Or while supply lasts
    End of Year Cleanout Sale on Limited Quantities as follows:
    EV1 Harness for Stock & TT225 injectors - $99.99 shipped in the US
    2 Available - Normally $125 shipped - $25 savings!
    EV6/EV14 Harness for Big Injectors - $130 shipped in the US
    1 Available- Normally $150 shipped - $20 savings!
    International Shipping available. Dm for quote
    DM me to purchase at these prices.
    Paypal, Venmo and Zelle accepted.
    Also available on eBay for slightly more to cover fees.
    May 22 2007
    Santa Monica CA
    DM to purchase or find me on Instagram - @cbarz
    May 22 2007
    Santa Monica CA
    Bump. Replacement Fuel Injection harnesses are in stock!
    EV1 for stock or TT225 injectors $110 shipped.
    EV6/EV14 for big injectors $120 shipped.
    PayPal accepted.
    DM me to order.
    Also, now making these to order. Plug and Play Longitudinal Coil Pack Harnesses - $140 shipped
    May 22 2007
    Santa Monica CA
    Bumpo
    Labor Day Sale
    I have two EV1 Stock Fuel Injector Harnesses available for $100 shipped in the US
    International shipping available for $30 additional
    DM to purchase
    PayPal, Zelle and ApplePay accepted
    Jul 10 2015
    Colorado
    I recently purchased one of these harnesses to repair an A4 for a family member. I was very impressed with the quality and service. The instructions provided were simple and straight forward. I appreciated the fact that a few extra pins were included, as I messed up a couple of them getting my technique down.
    It turns out that the root issue was a bad injector, but while troubleshooting, the harness crumbled, so a replacement was needed. I would (and probably will for my A4) purchase again. Thank you for offering these and keeping our cars on the road.
    Aug 11 2014
    Mass.
    I purchased one of these for my A4 with the ev14 injectors along with the crimpers he recommends. As people have already stated good instructions, communication, and dependable timeframes.
    Took me roughly 1 1/2 hours taking my time and all's well now that you rid my car of that crispy critter! I'm amazed my car could still run once I got a good look at it.....
    Thanks for producing these,
    Cheers
    Steve
    May 22 2007
    Santa Monica CA
    Back in stock
    May 22 2007
    Santa Monica CA
    Currently have 3 EV1 stock injector harnesses available and ready to ship.
    $130 shipped in the US. $160 shipped internationally. Paypal accepted. DM to purchase.
    Aug 13 2015
    LA
    DM
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by cleoo View Post
    DM
    Replied. Third time you have contacted me about something that I replied to and then you ghost me.
    Aug 13 2015
    LA
    Sorry about that. Wasn’t intentional and always don’t check the tapatalk. Send me your paypal and I’ll complete the sale.
    May 22 2007
    Santa Monica CA
    Got one left in this current batch
    May 22 2007
    Santa Monica CA
    Bumpo
