Results 1 to 10 of 10
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    Post New Product - CETE Automotive Memory Modules
    CETE Automotive has introduced some new memory modules that have the ability to memorize the drive select mode and/or stop/start assist setting on shutoff. The drive select memory is a great little addition for RS models which have the terrible design to drop out of RS modes to standard drive select modes when restarted.
    CETE Drive Select Memory and Stop/Start Memory Modules
    • Complete Control of Drive Select Remains
    • Complete Control of Stop/Start Remains
    • No More Need to Reset to Your Desired Drive Select on Startup
    • No More Need to Reset to Your Desired SSA Setting on Startup
    • Module Remembers Last SSA Setting Whether On or Off
    • No Need for Any Additional Startup Steps for SSA Memory
    • Tapping of Wiring is Required
    • Long Press of Steering Wheel Mute Button - Module Turns On/Off
    • Startup - Drive Select Mode and SSA Remain from Last Shutdown
    CETE Audi A3, S3, RS3 8Y Drive Memory Module <-Click link for more information
    CETE Audi A3, S3, RS3 8Y Stop/Start Memory Module <-Click link for more information
    Information:
    With this CETE Automotive drive select memory module you will no longer have your drive select set back to Auto or out of your chosen drive select mode on every startup. Especially useful for RS owners that want the car to restart in their chosen RS mode. The RS mode must be set with the touchscreen for it to be memorized for the next startup. The SSA module memorizes your Stop/Start system setting so no more turning the SSA off on every startup if you dislike that feature. With the long press of a factory button you can turn the module(s) on or off. The full factory control systems stay intact and functional. Both modules can be installed into one vehicle to have both functions memorized.
    Ordering:
    Modules are ready to ship now directly to your location. Ordering can be done directly through the link above which takes you to the Europrice website or with any authorized reseller. Shipping cost is not included in the product pricing and is calculated upon checkout depending on your location (you can estimate shipping by adding the product to your cart and viewing the car at any time). Tracking will be provided when module packages depart to each purchaser.
    Questions:
    If you have any questions or needs other than those posted above please don't hesitate to PM or email: [email protected]
    Cheers!
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Veteran Member Three Rings 0000 RS5's Avatar
    Jul 13 2015
    Only for MY 21+?
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by 0000 RS5 View Post
    Only for MY 21+?
    These would be specific to the newest generation of 8Y models.
    Cheers,
    www.europrice.us
    [email protected]
    Jul 30 2022
    San Francisco
    Any chance you could make one of these for seating position?
    I'd pay at least $500 to not have to manually adjust every time, since my wife and I swap who drives fairly often.
    2022 Turbo Blue TTRS
    Unitronic Stage 1 ECU & TCU - 91 Octane
    034 18" ZTF Wheels - 265/40/18 Pilot Sport All Season 4
    034 Billet Dogbone Insert
    034 Midpipes
    K&N Drop in Filter
    Unitronic 3" Turbo Inlet
    Unitronic Intercooler
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by Mooseman View Post
    Unfortunately seating memory is more complex as it usually involves the seat having motors with position switches or locators. Then those are wired to a seating module that has memory which communicates with the car and is wired to the memory switch. Cars that do have the memory seating can have those positions set to a specific key as well, but if the car does not have seat memory sadly there's a lot involved in adding seats that do have it.
    Cheers,
    www.europrice.us
    [email protected]
    Aug 27 2022
    La center Wa
    Any plans on the 8v?
    Sent from my SM-S908U using Audizine Forum mobile app
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by dbp510 View Post
    There is a stop/start memory module available for the 8V, but no drive select memory module available or in the works it would seem. I can inquire with CETE as to the technical feasibility of doing a drive select memory module for the 8V but the ones they've just released with the newest touch screen MMI specifically.
    Cheers,
    www.europrice.us
    [email protected]
    Aug 27 2022
    La center Wa
    Quote Originally Posted by [email protected] View Post
    Cheers,
    Okay, that sounds good. I hate the whole drive select function on our rs3's. If they come back with the possibility of it, i would love to hear.
    My car, however, doesn't have the stop start, so I'm not worried about that part.
    Thanks again.
    May 09 2023
    2012 Shadow Blue VW GTI
    Sacramento, CA
    What happened to the drive select module? The link takes you to a page not found and it isn’t listed with the electronics on the site.
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by FSTSNAL View Post
    There was an issue with the C8 drive select capable memory module that appears to be solved, switched power vs. constant on power to the module. This product was pulled for a few days just in case the issue was present with any other drive select memory modules, but after checking with RS3 8Y owners these are not effected.
    The product link is up and working again now. In stock as well.
    Cheers,
    www.europrice.us
    [email protected]
