Results 1 to 11 of 11
    Apr 09 2023
    Hawaii
    2009 A4 2.0t will this motor work?
    So I'm new to all the codes and swaps. My 2009 has a bad engine and I found a wrecked 2014 Allroad 2.0t locally. Does anyone know if I can use this engine? I believe the engine code for the 2014 is CPMB.
    Apr 20 2020
    '04 allroad 2.7T, '07 A4 2.0T qt, '10 A4 2.0T, '10 TT 2.0T qt, '02 Ford Ranger 3.0L.
    Chino, CA
    @Redline808 Yes, CPMB is the engine code. Also note the transmission code on the same line: NGR. It's a 8-speed quattro automatic (0BK). Guess you know that from the other thread.
    Apr 09 2023
    Hawaii
    Quote Originally Posted by mc_hotmail View Post
    I did not know that. Thank you. My A4 is also a quattro. Will the CPMB work in my 2009 A4?
    Apr 20 2020
    Chino, CA
    I doubt your CAEB ecu can work with the newer CPMB engine. You need to get the ECU too, which also means wiring harness. I haven't done it myself. It seems do-able, but a lot of work. If bought the donor outright, then swap both the engine and tranny, plus the ECU and wiring -- there goes your can of worm :) May be you need the center console too.
    Apr 09 2023
    Hawaii
    I was hoping to just use the CPMB long block, use my intake, accessories, harness, ecu and transmission. I don't know if this is possible?
    Jul 16 2018
    Atlanta
    That's exactly what you have to do. You're just using the "core" from the new-to-you engine. All the bolt-ons you'll transplant over.
    Apr 09 2023
    Hawaii
    Quote Originally Posted by Smac770 View Post
    Perfect, Thanks for the confirmation! Will keep the forum updated with my progress.
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    Is a 2014 engine a EA888 gen 3? If so, the combustion chamber and pistons are different. CR was increased too to be "more efficient" (emissions reasons). I do not know the exactly specifics other than that. Does anyone else?
    I call it out in case there's piston to valve clearance.
    Sent from my SM-N976V using Audizine Forum mobile app
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Jul 16 2018
    Atlanta
    B8.5 had the Gen3 only in some markets. NAR was definitely not one of them.
    Feb 21 2024
    Minnesota
    what's considered all the bolt ons to swap over? My 09 has low oil pressure and if the oil pump doesn't work fix it im just gonna get an engine from a 2013 or 14.
    Jul 16 2018
    Atlanta
    It's been posted before. If it's a B8.5 CAEx, you'll need the accessory bracket and the crank position sensor. If it's a B8.5 CPMx, you'll also need your injectors, fuel rail, and intake manifold. There's probably more, but that's the highlights.
